跳转到主内容
Dell Inspiron 3542 Heat Sink Replacement
你所需要的
  1. Dell Inspiron 3542 Heat Sink Replacement, Heat Sink: 步骤 1 中的图像 1,2 Dell Inspiron 3542 Heat Sink Replacement, Heat Sink: 步骤 1 中的图像 2,2
    • Slide the latches on both sides of the computer outward to unlock the battery.
    • Remove the battery from the computer.
  2. Dell Inspiron 3542 Heat Sink Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 3542 Heat Sink Replacement: 步骤 2 中的图像 2,2
    • Remove the screw. (1x M2 x 3mm)
    • Slide down the access door and remove it.
  3. Dell Inspiron 3542 Heat Sink Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 3542 Heat Sink Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 3542 Heat Sink Replacement: 步骤 3 中的图像 3,3
    • Remove the screw. (1 x m2 x 3mm)
    • Move the hard drive to the open area and remove it.
  4. Dell Inspiron 3542 Heat Sink Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 3542 Heat Sink Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 3542 Heat Sink Replacement: 步骤 4 中的图像 3,3
    • Unplug the black and white antenna cables from the wireless card.
    • Remove the screw. (1 x M2 x 3mm)
    • Remove the wireless card from the laptop.
  5. Dell Inspiron 3542 Heat Sink Replacement: 步骤 5 中的图像 1,3 Dell Inspiron 3542 Heat Sink Replacement: 步骤 5 中的图像 2,3 Dell Inspiron 3542 Heat Sink Replacement: 步骤 5 中的图像 3,3
    • Turn over the laptop and open it.
    • Use the plastic prying device to release the keyboard.
    • Lift the keyboard.
    • Unplug the cable connecting the keyboard to the laptop.
    • Remove the keyboard.
    • Remove the screws. (3 x M2.5 x 5mm)
  6. Dell Inspiron 3542 Heat Sink Replacement: 步骤 6 中的图像 1,2 Dell Inspiron 3542 Heat Sink Replacement: 步骤 6 中的图像 2,2
    • Unplug the touch pad cables located on the palm rest.
  7. Dell Inspiron 3542 Heat Sink Replacement: 步骤 7 中的图像 1,3 Dell Inspiron 3542 Heat Sink Replacement: 步骤 7 中的图像 2,3 Dell Inspiron 3542 Heat Sink Replacement: 步骤 7 中的图像 3,3
    • Carefully unsnap the palm rest from the rest of the laptop.
    • Remove the palm rest.
  8. Dell Inspiron 3542 Heat Sink Replacement: 步骤 8 中的图像 1,1
    • Unplug the cable that connects to the motherboard.
    • Remove the DC jack from the laptop.
  9. Dell Inspiron 3542 Heat Sink Replacement: 步骤 9 中的图像 1,1
    • Loosen the cables on the antenna.
  10. Dell Inspiron 3542 Heat Sink Replacement: 步骤 10 中的图像 1,1
    • Remove the screws. (1 x M2 x 3mm)
    • Unplug the circuit board from the rest of the computer.
  11. Dell Inspiron 3542 Heat Sink Replacement: 步骤 11 中的图像 1,2 Dell Inspiron 3542 Heat Sink Replacement: 步骤 11 中的图像 2,2
    • Loosen the tape on the left side of the laptop.
    • Unplug the display cable.
  12. Dell Inspiron 3542 Heat Sink Replacement: 步骤 12 中的图像 1,3 Dell Inspiron 3542 Heat Sink Replacement: 步骤 12 中的图像 2,3 Dell Inspiron 3542 Heat Sink Replacement: 步骤 12 中的图像 3,3
    • Unplug the cable on the bottom part of the mother board.
    • Remove the motherboard from the laptop.
  13. Dell Inspiron 3542 Heat Sink Replacement: 步骤 13 中的图像 1,3 Dell Inspiron 3542 Heat Sink Replacement: 步骤 13 中的图像 2,3 Dell Inspiron 3542 Heat Sink Replacement: 步骤 13 中的图像 3,3
    • Turn over the motherboard.
    • Unplug the cooling fan.
    • Loosen the 3 screws from the heat sink.
    • Remove the heat sink.
结论
2等其他人完成本指南。
Rachel lindsey
于03/21/17注册
658 声望
创作了5篇指南
团队
Texas Tech, Team S46-G1, Bennett Spring 2017 Texas Tech, Team S46-G1, Bennett Spring 2017 的会员
TTU-BENNETT-S17S46G1
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 1,121
