简介
Access the motherboard to replace the CMOS battery if your computer is having issues tracking the date and time. It is recommended to wear an anti-static wrist strap to avoid damaging the electronic components of the computer.
你所需要的
Remove the screws to take off the surface cover.
Dont wast you time for these steps because this model 3521 ,only 2nd step enough for remove cmos battery . Once remove the Surface Cover ,you can see the cmos battery .. no need to remove all the components .thanks me later .
Remove screws securing the hard drive
Remove hard drive by pulling on the tab to slide it out.
Remove the screws securing the optical drive, then slide out the optical drive.
Remove the ribbon cable by pulling up on the tab where it is attached, then slide it out.
Unplug the smaller ribbon cable by pulling up on the tab where it is attached, then slide it out.
Unplug the motherboard cable by pulling up on the tab where it is attached, then slide it out.
Unplug the white ribbon cable by pulling up on the tab where it is attached, then slide it out.
Unplug the black and white cables connected to the Wi-Fi chip.
Locate and disconnect connecting cables on motherboard.
Remove the remaining screws securing the motherboard to remove it.
What do the screws look like after thay are out
Flip over motherboard and locate CMOS battery
Pry off battery with spudger.
Place new CMOS battery in motherboard.
Is the battery replacement required if the laptop doesn't detect the battery charging
另外一个人完成了本指南。
2条评论
Thank you, kind man)
Stuff Srilanka - 回复
