跳转到主内容
加入维修社区 - 创建账户
Dell Inspiron 3520 Optical Drive Replacement
你所需要的
  1. Dell Inspiron 3520 Optical Drive Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 3520 Optical Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn off notebook
    • Set the notebook upside down with the battery facing away from you.
    • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
    询问修复机器人
  2. Dell Inspiron 3520 Optical Drive Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 3520 Optical Drive Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 3520 Optical Drive Replacement: 步骤 2 中的图像 3,3
    • Slide the right tab to the right to unlock the battery.
    • Slide and hold the the left tab to the left to release the battery from the unit.
    • Finally, remove the battery by sliding it away from the unit and yourself.
    询问修复机器人
  3. Dell Inspiron 3520 Optical Drive Replacement, Keyboard: 步骤 3 中的图像 1,2 Dell Inspiron 3520 Optical Drive Replacement, Keyboard: 步骤 3 中的图像 2,2
    • Locate the four tabs along the top edge of the keyboard.
    • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
    询问修复机器人
  4. Dell Inspiron 3520 Optical Drive Replacement: 步骤 4 中的图像 1,1
    • Slide the keyboard forward towards the screen to release the bottom tabs.
    询问修复机器人
  5. Dell Inspiron 3520 Optical Drive Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 3520 Optical Drive Replacement: 步骤 5 中的图像 2,2
    • Carefully lift the board up and locate the connecting cable.
    • Gently pull the end of the cable free from the port on the laptop.
    询问修复机器人
  6. Dell Inspiron 3520 Optical Drive Replacement, Optical Drive: 步骤 6 中的图像 1,2 Dell Inspiron 3520 Optical Drive Replacement, Optical Drive: 步骤 6 中的图像 2,2
    • Locate and remove the 4mm Phillips #00 mounting screw.
    询问修复机器人
  7. Dell Inspiron 3520 Optical Drive Replacement: 步骤 7 中的图像 1,2 Dell Inspiron 3520 Optical Drive Replacement: 步骤 7 中的图像 2,2
    • Push the optical drive from the inside a little bit to dislodge it.
    • Grab the drive with your hand from the outside and slide it free.
    询问修复机器人
结论
5等其他人完成本指南。
Ian
于01/30/15注册
1,611 声望
创作了5篇指南
团队
USF Tampa, Team 16-2, Watkins Winter 2015 USF Tampa, Team 16-2, Watkins Winter 2015 的会员
USFT-WATKINS-W15S16G2
3 名成员
创作了5篇指南
1指南评论
...screaming.....i love my dell 3520 it is awesome, it is still holding up.."hooray!!!!
Madeline Jones - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 52
总计 3,065
