跳转到主内容
Dell Inspiron 3148 RAM Replacement
你所需要的
  1. Dell Inspiron 3148 RAM Replacement, Back Panel: 步骤 1 中的图像 1,2 Dell Inspiron 3148 RAM Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
    • Flip the device over so the backside is facing you.
  2. Dell Inspiron 3148 RAM Replacement: 步骤 2 中的图像 1,1
    • Using the Phillips #1 screwdriver, remove all nine 7mm screws.
  3. Dell Inspiron 3148 RAM Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 3148 RAM Replacement: 步骤 3 中的图像 2,2
    • Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
    • Be aware, the back panel is kept in place by magnetic clips. They will offer some resistance, but continue to gently leverage upwards.
  4. Dell Inspiron 3148 RAM Replacement, RAM: 步骤 4 中的图像 1,1
    • Locate the RAM chips on the motherboard.
  5. Dell Inspiron 3148 RAM Replacement: 步骤 5 中的图像 1,1
    • There are two tabs on either side of the RAM chip. Pull them away from the chip.
  6. Dell Inspiron 3148 RAM Replacement: 步骤 6 中的图像 1,2 Dell Inspiron 3148 RAM Replacement: 步骤 6 中的图像 2,2
    • The RAM chip will pop up out of the slot.
    • Pinch the RAM between two fingers, making minimal contact. Gently pull away from its port.
    • Remove the RAM from the device.
结论
另外一个人完成了本指南。
团队
UMass Dartmouth, Team S1-G2, Simcock Fall 2018 UMass Dartmouth, Team S1-G2, Simcock Fall 2018 的会员
UMASSD-SIMCOCK-F18S1G2
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 12
总计 301
