跳转到主内容
Dell Inspiron 3148 Keyboard Replacement
你所需要的
  1. Dell Inspiron 3148 Keyboard Replacement, Back Panel: 步骤 1 中的图像 1,2 Dell Inspiron 3148 Keyboard Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
    • Flip the device over so the backside is facing you.
  2. Dell Inspiron 3148 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Using the Phillips #1 screwdriver, remove all nine 7mm screws.
  3. Dell Inspiron 3148 Keyboard Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 3148 Keyboard Replacement: 步骤 3 中的图像 2,2
    • Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
    • Be aware, the back panel is kept in place by magnetic clips. They will offer some resistance, but continue to gently leverage upwards.
  4. Dell Inspiron 3148 Keyboard Replacement, Battery: 步骤 4 中的图像 1,1
    • Remove the three 4mm screws holding battery in place using the Phillips #0 screwdriver.
  5. Dell Inspiron 3148 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Using the iFixit opening tools, lift the battery out of its housing.
  6. Dell Inspiron 3148 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Once loosened, use your fingers to lift the battery up and out of its housing.
    • There is a small cable which sits in a rut in the top of the battery. Ensure that it is pushed out of the way before removing completely.
  7. Dell Inspiron 3148 Keyboard Replacement: 步骤 7 中的图像 1,1
    • Remove the battery completely.
  8. Dell Inspiron 3148 Keyboard Replacement, RAM: 步骤 8 中的图像 1,1
    • Locate the RAM chips on the motherboard.
  9. Dell Inspiron 3148 Keyboard Replacement: 步骤 9 中的图像 1,1
    • There are two tabs on either side of the RAM chip. Pull them away from the chip.
  10. Dell Inspiron 3148 Keyboard Replacement: 步骤 10 中的图像 1,2 Dell Inspiron 3148 Keyboard Replacement: 步骤 10 中的图像 2,2
    • The RAM chip will pop up out of the slot.
    • Pinch the RAM between two fingers, making minimal contact. Gently pull away from its port.
    • Remove the RAM from the device.
  11. Dell Inspiron 3148 Keyboard Replacement, Hard Drive: 步骤 11 中的图像 1,3 Dell Inspiron 3148 Keyboard Replacement, Hard Drive: 步骤 11 中的图像 2,3 Dell Inspiron 3148 Keyboard Replacement, Hard Drive: 步骤 11 中的图像 3,3
    • If there is a piece of tape connecting the hard drive and a small power cord, remove the tape.
    • Using the Phillips #0 screwdriver, remove the two 4mm screws.
  12. Dell Inspiron 3148 Keyboard Replacement: 步骤 12 中的图像 1,3 Dell Inspiron 3148 Keyboard Replacement: 步骤 12 中的图像 2,3 Dell Inspiron 3148 Keyboard Replacement: 步骤 12 中的图像 3,3
    • Notice: there is a small data cable connecting the hard drive to the motherboard. Do not attempt to lift the hard drive all the way out before removing this cable.
    • Lift the hard drive slightly out of the device.
    • Grasp the head of the cable, not the cable itself.
    • Pull away from the hard drive, removing the data cable. The hard drive may now be fully removed.
  13. Dell Inspiron 3148 Keyboard Replacement, Fan: 步骤 13 中的图像 1,3 Dell Inspiron 3148 Keyboard Replacement, Fan: 步骤 13 中的图像 2,3 Dell Inspiron 3148 Keyboard Replacement, Fan: 步骤 13 中的图像 3,3
    • If there is tape on your fan, remove the tape.
    • Remove the two 2mm screws on the fan enclosure using the Phillips #00 screwdriver.
  14. Dell Inspiron 3148 Keyboard Replacement: 步骤 14 中的图像 1,2 Dell Inspiron 3148 Keyboard Replacement: 步骤 14 中的图像 2,2
    • Unscrew the three 4mm screws holding down the heat sink of the fan using the Phillips #00 screwdriver.
    • The three 4mm screws found in the heat sink will remain attached to the heat sink. This is okay as long as they are detached from the motherboard.
  15. Dell Inspiron 3148 Keyboard Replacement: 步骤 15 中的图像 1,1
    在这个步骤中使用的工具:
    • Use the tweezers to gently pull the power supply cable from its port.
  16. Dell Inspiron 3148 Keyboard Replacement: 步骤 16 中的图像 1,1
    • Grasp the fan and lift upward. Remove the fan from the device.
  17. Dell Inspiron 3148 Keyboard Replacement, CMOS Battery: 步骤 17 中的图像 1,3 Dell Inspiron 3148 Keyboard Replacement, CMOS Battery: 步骤 17 中的图像 2,3 Dell Inspiron 3148 Keyboard Replacement, CMOS Battery: 步骤 17 中的图像 3,3
    在这个步骤中使用的工具:
    • Using a pair of tweezers, lift the exposed edge of the CMOS battery upward.
    • Once the CMOS battery has been loosened, remove it from the device.
  18. Dell Inspiron 3148 Keyboard Replacement, Motherboard: 步骤 18 中的图像 1,1
    • Remove the keyboard cable from its ZIF connector by flipping up the locking tab on the connector and then pulling the cable out.
  19. Dell Inspiron 3148 Keyboard Replacement: 步骤 19 中的图像 1,1
    • Remove the touch pad cable from its ZIF connector.
  20. Dell Inspiron 3148 Keyboard Replacement: 步骤 20 中的图像 1,1
    • Remove one 3.41mm screw using a Phillips #000 screwdriver.
    • Remove the two 3.41mm screws using a Phillips #000 screwdriver.
    • Remove motherboard.
  21. Dell Inspiron 3148 Keyboard Replacement, Keyboard: 步骤 21 中的图像 1,2 Dell Inspiron 3148 Keyboard Replacement, Keyboard: 步骤 21 中的图像 2,2
    • Using a Phillips #000 screwdriver, remove single 4.1mm screw from the SD card reader board.
    • Remove the SD card reader board.
    • Remove the keyboard.
结论
另外一个人完成了本指南。
一条评论
This guide is a joke - the last step leaves out the part about removing the paper insulation (black sheet), and then you have about 25 plastic welded posts that hold the metal shield over the keyboard. To "Remove the keyboard" as the purported author states, you'll have to break the posts, remove the shield, then hope you can get it all back in place without damage. I would have never ordered a replacement keyboard knowing this. Pure BS.....
Matty Klem - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 299
