跳转到主内容
Dell Inspiron 17R-N7110 RAM Replacement
你所需要的
  1. Dell Inspiron 17R-N7110 RAM Replacement, Battery: 步骤 1 中的图像 1,3 Dell Inspiron 17R-N7110 RAM Replacement, Battery: 步骤 1 中的图像 2,3 Dell Inspiron 17R-N7110 RAM Replacement, Battery: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    • Do not touch any electronic components without wearing the anti-static wrist strap. Failure to do so poses a risk of static electric shock, and may cause damage to components.
    • Place the laptop on a flat surface with the Dell logo upside down.
    • Flip the laptop over. The battery will be in the top center.
  2. Dell Inspiron 17R-N7110 RAM Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 17R-N7110 RAM Replacement: 步骤 2 中的图像 2,2
    • Slide both the left lock and right lock, towards the center of the battery.
    • Push upwards on the grip on the bottom of the battery to remove it.
  3. Dell Inspiron 17R-N7110 RAM Replacement, RAM: 步骤 3 中的图像 1,2 Dell Inspiron 17R-N7110 RAM Replacement, RAM: 步骤 3 中的图像 2,2
    • Using a Phillips #1 screwdriver, unscrew the .7mm screw at the top of the RAM compartment as pictured.
    • Use a metal Jimmy to pry open the RAM cover from the top of the compartment.
  4. Dell Inspiron 17R-N7110 RAM Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 17R-N7110 RAM Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 17R-N7110 RAM Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    $7.95
    • Do not touch the RAM sticks without releasing static electricity build up. Make sure you are wearing the anti-static wrist strap, and that the metal clip is attached to a grounded metal object.
    • There are two small plastic prongs to the sides of the first RAM stick. Push the prongs away from each other to release the RAM stick.
    • Gently remove the RAM stick.
    • If your laptop has a second RAM stick located underneath the first one, repeat this step to remove it.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 15
总计 1,207
