简介
This guide will cover how to replace the palm rest component of a Dell Inspiron 17R-N7010 computer as well as how to access the inner hardware of the laptop including but not limited to the motherboard, fans, and processors.
Before using this guide make sure that the computer is powered off and that you are in a clean and clear workspace where it will be easy to keep track of all parts.
This guide requires basic knowledge of how to use tools like a screwdriver and a spudger. Remember to take your time when using the spudger and to not rush. It may take longer but you will get the job done right if you take your time when attempting this guide.
工具
配件
没有特定配件。
Still looking at the back of the laptop, locate and unscrew the four screws highlighted in green.
Flip the laptop over and open it to view the face of the keyboard.
Close the laptop and flip it over so that you are viewing the bottom of the laptop.
To remove the back cover, locate and unscrew the two screws marked in green.
Following this, slide the CD drive out in order to locate and access the final three screws, which are marked in red.
Next, remove the three screws marked in red.
To safely remove the top cover, insert a spudger underneath the grey surface where the blue circle is shown. Pry upwards with the spudger in order to detach the locks.
Work clockwise starting from the indicated blue circle, inserting the spudger under the grey cover and lifting up in order to detach the locks.
