跳转到主内容
Dell Inspiron 17R-5737 Palmrest Replacement
你所需要的
  1. Dell Inspiron 17R-5737 Palmrest Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the laptop is off before attempting to remove the battery.
    • Flip over your laptop so that the battery faces you.
  2. Dell Inspiron 17R-5737 Palmrest Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 17R-5737 Palmrest Replacement: 步骤 2 中的图像 2,2
    • Slide each latch away from the battery to unlock it.
  3. Dell Inspiron 17R-5737 Palmrest Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 17R-5737 Palmrest Replacement: 步骤 3 中的图像 2,2
    • Lift the battery upwards to remove it.
    • Continue holding the latches when removing the battery.
  4. Dell Inspiron 17R-5737 Palmrest Replacement, Optical Drive: 步骤 4 中的图像 1,2 Dell Inspiron 17R-5737 Palmrest Replacement, Optical Drive: 步骤 4 中的图像 2,2
    • Remove one 4.8mm screw with a JIS #00 screwdriver.
    • Remove the optical drive.
  5. Dell Inspiron 17R-5737 Palmrest Replacement, Access Panel: 步骤 5 中的图像 1,1
    • Remove two 4.8mm screws with a JIS #00 screwdriver.
    • Remove the access panel.
  6. Dell Inspiron 17R-5737 Palmrest Replacement, Hard Drive: 步骤 6 中的图像 1,3 Dell Inspiron 17R-5737 Palmrest Replacement, Hard Drive: 步骤 6 中的图像 2,3 Dell Inspiron 17R-5737 Palmrest Replacement, Hard Drive: 步骤 6 中的图像 3,3
    • Remove three 4.8mm screws from the hard drive with a JIS #00 screwdriver.
    • Slide the hard drive to the left.
    • Slide the hard drive to the right and up.
  7. Dell Inspiron 17R-5737 Palmrest Replacement, RAM: 步骤 7 中的图像 1,2 Dell Inspiron 17R-5737 Palmrest Replacement, RAM: 步骤 7 中的图像 2,2
    • Slide the two clips away from the RAM.
    • Lift the RAM out.
  8. Dell Inspiron 17R-5737 Palmrest Replacement, Keyboard: 步骤 8 中的图像 1,1
    • A metal spudger can scratch delicate internal parts. Be extra careful when removing the keyboard.
    • Use a metal spudger to loosen the main frame of the keyboard.
    • A metal spudger should be used instead of a plastic one because a plastic one will probably break.
    • Make sure to get the spudger under the entire keyboard and not just under the keys.
  9. Dell Inspiron 17R-5737 Palmrest Replacement: 步骤 9 中的图像 1,3 Dell Inspiron 17R-5737 Palmrest Replacement: 步骤 9 中的图像 2,3 Dell Inspiron 17R-5737 Palmrest Replacement: 步骤 9 中的图像 3,3
    • Slowly lift the keyboard.
    • Lift the locking flap that holds the ribbon cable in place.
    • The white line on this ribbon cable marks the edge of the connection area. To reinstall, insert the cable into the connector up to this line, and then close the locking flap.
    • Remove the keyboard.
  10. Dell Inspiron 17R-5737 Palmrest Replacement, Palmrest: 步骤 10 中的图像 1,3 Dell Inspiron 17R-5737 Palmrest Replacement, Palmrest: 步骤 10 中的图像 2,3 Dell Inspiron 17R-5737 Palmrest Replacement, Palmrest: 步骤 10 中的图像 3,3
    • Remove two 1.6mm screws from beneath the optical drive with a JIS #00 screwdriver.
    • Remove the nine remaining 4.8mm screws from the back of the computer with a JIS #00 screwdriver.
  11. Dell Inspiron 17R-5737 Palmrest Replacement: 步骤 11 中的图像 1,3 Dell Inspiron 17R-5737 Palmrest Replacement: 步骤 11 中的图像 2,3 Dell Inspiron 17R-5737 Palmrest Replacement: 步骤 11 中的图像 3,3
    • Remove the two exposed ribbon cables.
    • Remove the palmrest.
结论
Mack Chabot
于10/18/17注册
645 声望
创作了6篇指南
团队
UMass Dartmouth, Team S3-G7, Bailey Fall 2017 UMass Dartmouth, Team S3-G7, Bailey Fall 2017 的会员
UMASSD-BAILEY-F17S3G7
3 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 253
