跳转到主内容
Dell Inspiron 17R-5721 RAM Replacement
你所需要的
  1. Dell Inspiron 17R-5721 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Located on the bottom of the laptop’s external shell, there should be two plastic sliding tabs to the right and left of the battery pack. Using your fingers, push these two tabs away from each other, toward the sides of the machine.
    • This mechanically unlocks the battery pack from its slot at the back of the machine.
  2. Dell Inspiron 17R-5721 RAM Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 17R-5721 RAM Replacement: 步骤 2 中的图像 2,2
    • Using your fingernails, pry the battery pack away from the rest of the machine, at the physical seam between the pack and the laptop’s plastic case.
    • This may take some effort to accomplish.
    • Remove the battery.
  3. Dell Inspiron 17R-5721 RAM Replacement, Access Panel: 步骤 3 中的图像 1,1
    • Using a Phillips #000 screwdriver, loosen the two screws at the top left and top right of the access door.
    • These two captive screws will loosen but will not separate from the panel.
  4. Dell Inspiron 17R-5721 RAM Replacement: 步骤 4 中的图像 1,1
    • Using a spudger, pry into the gap in the plastic revealed by loosening the screws.
    • Lift off the access panel.
  5. Dell Inspiron 17R-5721 RAM Replacement, RAM: 步骤 5 中的图像 1,1
    • Using your fingers, separate the metal tabs located on the left and right of each stick of RAM by pulling them apart from each other.
  6. Dell Inspiron 17R-5721 RAM Replacement: 步骤 6 中的图像 1,1
    • Pull each RAM stick out of the machine, separating each piece from its respective slot.
结论
Thomas Griffin
于03/21/19注册
915 声望
创作了9篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 8
总计 185
