跳转到主内容
Dell Inspiron 17R-5721 Palmrest Assembly Replacement
你所需要的
  1. Dell Inspiron 17R-5721 Palmrest Assembly Replacement, Battery: 步骤 1 中的图像 1,1
    • Located on the bottom of the laptop’s external shell, there should be two plastic sliding tabs to the right and left of the battery pack. Using your fingers, push these two tabs away from each other, toward the sides of the machine.
    • This mechanically unlocks the battery pack from its slot at the back of the machine.
  2. Dell Inspiron 17R-5721 Palmrest Assembly Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 17R-5721 Palmrest Assembly Replacement: 步骤 2 中的图像 2,2
    • Using your fingernails, pry the battery pack away from the rest of the machine, at the physical seam between the pack and the laptop’s plastic case.
    • This may take some effort to accomplish.
    • Remove the battery.
  3. Dell Inspiron 17R-5721 Palmrest Assembly Replacement, Access Panel: 步骤 3 中的图像 1,1
    • Using a Phillips #000 screwdriver, loosen the two screws at the top left and top right of the access door.
    • These two captive screws will loosen but will not separate from the panel.
  4. Dell Inspiron 17R-5721 Palmrest Assembly Replacement: 步骤 4 中的图像 1,1
    • Using a spudger, pry into the gap in the plastic revealed by loosening the screws.
    • Lift off the access panel.
  5. Dell Inspiron 17R-5721 Palmrest Assembly Replacement, Hard Drive: 步骤 5 中的图像 1,1
    • Using a Phillips #000 screwdriver, remove the three 5 mm screws securing the hard drive to the laptop.
  6. Dell Inspiron 17R-5721 Palmrest Assembly Replacement: 步骤 6 中的图像 1,1
    • Grabbing from the left of the hard drive, slide the part to the left and pull up, lifting it away from the machine.
  7. Dell Inspiron 17R-5721 Palmrest Assembly Replacement, RAM: 步骤 7 中的图像 1,1
    • Using your fingers, separate the metal tabs located on the left and right of each stick of RAM by pulling them apart from each other.
  8. Dell Inspiron 17R-5721 Palmrest Assembly Replacement: 步骤 8 中的图像 1,1
    • Pull each RAM stick out of the machine, separating each piece from its respective slot.
  9. Dell Inspiron 17R-5721 Palmrest Assembly Replacement, Keyboard: 步骤 9 中的图像 1,1
    • Open the laptop to reveal the keyboard.
    • Using a plastic opening tool, pry the keyboard free from the palmrest assembly at the plastic tabs located across the top of the keyboard.
  10. Dell Inspiron 17R-5721 Palmrest Assembly Replacement: 步骤 10 中的图像 1,1
    • Once free from the palmrest, flip over the keyboard.
    • Unplug the ribbon cable connecting the keyboard to the motherboard.
    • Remove the keyboard.
  11. Dell Inspiron 17R-5721 Palmrest Assembly Replacement, Palmrest Assembly: 步骤 11 中的图像 1,1
    • On the bottom of the laptop, use the Phillips screwdriver to remove nine total 5 mm screws from the following locations:
    • Four screws at each corner of the laptop’s bottom panel
    • Two screws within the battery slot
    • One screw to the left of the hard drive
    • Two screws located below the RAM
  12. Dell Inspiron 17R-5721 Palmrest Assembly Replacement: 步骤 12 中的图像 1,1
    • Using your fingers, unplug the two palmrest ribbon cables found at the bottom left of the integrated keyboard’s slot.
  13. Dell Inspiron 17R-5721 Palmrest Assembly Replacement: 步骤 13 中的图像 1,1
    • Use the metal spudger at the bottom-right corner of the palmrest’s faceplate to pry underneath the plastic casing and separate the palmrest from the laptop’s bottom plastic shell.
    • Once the spudger has leverage between the two halves of the case, work the tool around the right, bottom, and left edges of the palmrest, prying the top from the bottom at around every half-inch.
    • Lift off the palmrest assembly.
结论
Thomas Griffin
于03/21/19注册
915 声望
创作了9篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 181
