跳转到主内容
Dell Inspiron 17R-5721 Keyboard Replacement
你所需要的
  1. Dell Inspiron 17R-5721 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Located on the bottom of the laptop’s external shell, there should be two plastic sliding tabs to the right and left of the battery pack. Using your fingers, push these two tabs away from each other, toward the sides of the machine.
    • This mechanically unlocks the battery pack from its slot at the back of the machine.
  2. Dell Inspiron 17R-5721 Keyboard Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 17R-5721 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Using your fingernails, pry the battery pack away from the rest of the machine, at the physical seam between the pack and the laptop’s plastic case.
    • This may take some effort to accomplish.
    • Remove the battery.
  3. Dell Inspiron 17R-5721 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Open the laptop to reveal the keyboard.
    • Using a plastic opening tool, pry the keyboard free from the palmrest assembly at the plastic tabs located across the top of the keyboard.
  4. Dell Inspiron 17R-5721 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Once free from the palmrest, flip over the keyboard.
    • Unplug the ribbon cable connecting the keyboard to the motherboard.
    • Remove the keyboard.
结论
Thomas Griffin
于03/21/19注册
915 声望
创作了9篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 11
总计 278
