跳转到主内容
Dell Inspiron 1750 Screen Replacement
你所需要的
  1. Dell Inspiron 1750 Screen Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 1750 Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Unplug the laptop before changing the battery to avoid electric shock.
    • Place the laptop on a flat stable surface.
    • Flip the laptop over so the underside is visible.
  2. Dell Inspiron 1750 Screen Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 1750 Screen Replacement: 步骤 2 中的图像 2,2
    • Locate the battery lock switch.
    • Slide the lock switch to the left (away from the lock symbol).
    • Slide the battery out away from the laptop.
  3. Dell Inspiron 1750 Screen Replacement, Dell Inspiron 1750 Teardown: 步骤 3 中的图像 1,1
    • Separate the screws by size and head type. Be sure to keep them in a safe place.
    • Remove the sixteen 2mm Phillips #00 screws from the bottom of the laptop.
    • Remove the two 2mm Phillips #0 screws from the hard drive port.
  4. Dell Inspiron 1750 Screen Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 1750 Screen Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 1750 Screen Replacement: 步骤 4 中的图像 3,3
    • Keep your hand pressed firmly on the back panel to prevent it from falling.
    • Flip the laptop over horizontally and open up the lid.
    • Insert the tip of the plastic opening tool into the upper left corner of the panel.
    • Keeping its tip under the top panel, slide the plastic opening tool around the panel until the panel is completely loose. Next gently remove the panel.
    • Remove the four 2mm Phillips #0 screws at the top of the keyboard.
    • Slide the plastic opening tool around the keyboard until the keyboard is completely loose. Gently remove the keyboard.
  5. Dell Inspiron 1750 Screen Replacement: 步骤 5 中的图像 1,3 Dell Inspiron 1750 Screen Replacement: 步骤 5 中的图像 2,3 Dell Inspiron 1750 Screen Replacement: 步骤 5 中的图像 3,3
    • Do not lift the keyboard completely free to avoid damaging its connections to the laptop interior.
    • Locate the small black latch attached to blue tape.
    • Lift the small latch with your finger and pull the blue tape from its port.
    • Slide the keyboard away from the mousepad and set it aside.
  6. Dell Inspiron 1750 Screen Replacement: 步骤 6 中的图像 1,3 Dell Inspiron 1750 Screen Replacement: 步骤 6 中的图像 2,3 Dell Inspiron 1750 Screen Replacement: 步骤 6 中的图像 3,3
    • Always pull wires from their plastic ends, not their cables, to avoid wire damage.
    • Locate the three wires in the top left corner of the metal panel.
    • Use the spudger to push the two cables out of their ports.
    • Pull the blue tab directly up to remove middle wire.
  7. Dell Inspiron 1750 Screen Replacement: 步骤 7 中的图像 1,2 Dell Inspiron 1750 Screen Replacement: 步骤 7 中的图像 2,2
    • Remove the three 1mm Phillips #00 screws on the metal plate.
    • Lift the black cover and slide the blue tab away from the cover.
  8. Dell Inspiron 1750 Screen Replacement: 步骤 8 中的图像 1,3 Dell Inspiron 1750 Screen Replacement: 步骤 8 中的图像 2,3 Dell Inspiron 1750 Screen Replacement: 步骤 8 中的图像 3,3
    • Gently remove the three grey wires from the metal tabs.
    • Insert the tip of the plastic opening tool into the bottom left corner of the panel.
    • Gently lift off the top metal panel.
  9. Dell Inspiron 1750 Screen Replacement, Screen: 步骤 9 中的图像 1,3 Dell Inspiron 1750 Screen Replacement, Screen: 步骤 9 中的图像 2,3 Dell Inspiron 1750 Screen Replacement, Screen: 步骤 9 中的图像 3,3
    • Use the spudger to lift the wires from their connections.
    • Remember to pull wires from their plastic ends, not their cables, to avoid wire damage.
    • Flip the laptop over and pull the connections through until they are free from the laptop interior.
  10. Dell Inspiron 1750 Screen Replacement: 步骤 10 中的图像 1,2 Dell Inspiron 1750 Screen Replacement: 步骤 10 中的图像 2,2
    • Remove the two 2mm Phillips #0 screws from the screen hinges.
    • Lift the screen away from the laptop and gently set it down.
    • Put the rest of the laptop aside.
  11. Dell Inspiron 1750 Screen Replacement: 步骤 11 中的图像 1,3 Dell Inspiron 1750 Screen Replacement: 步骤 11 中的图像 2,3 Dell Inspiron 1750 Screen Replacement: 步骤 11 中的图像 3,3
    • Use the plastic opening tool to remove the plastic cover from the screen.
    • Remove the eight 2mm Phillips #0 screws from the corners of the screen.
    • Lift the screen away from the back panel.
  12. Dell Inspiron 1750 Screen Replacement: 步骤 12 中的图像 1,2 Dell Inspiron 1750 Screen Replacement: 步骤 12 中的图像 2,2
    • Remove the four 2mm Phillips #0 screws from the sides of the screen.
    • Remove the side railings from both sides of the screen by pulling the railings gently away from the screen.
结论
3等其他人完成本指南。
Tina Rickard
于04/07/14注册
759 声望
创作了5篇指南
团队
Cal Poly, Team 6-3, Forte Spring 2014 Cal Poly, Team 6-3, Forte Spring 2014 的会员
CPSU-FORTE-S14S6G3
5 名成员
创作了7篇指南
2条评论
Succeed ! Thanks.
Note: @ First opening, I add to do step 9 before the step 8. The antenna wire prevent you to "Gently lift off the top metal panel".
wxadha - 回复
My screen almost always has a pink spotty look. How do I know if I need to replace the screen, or just the wires?
Kathleen - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 3,705
