跳转到主内容
Dell Inspiron 1721 DVD Drive Replacement
你所需要的
  1. Dell Inspiron 1721 DVD Drive Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 1721 DVD Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Slide tabs outward to undo the locks.
    • Grab and pull the battery away from the device to remove.
  2. Dell Inspiron 1721 DVD Drive Replacement, Hinge Plate Cover: 步骤 2 中的图像 1,3 Dell Inspiron 1721 DVD Drive Replacement, Hinge Plate Cover: 步骤 2 中的图像 2,3 Dell Inspiron 1721 DVD Drive Replacement, Hinge Plate Cover: 步骤 2 中的图像 3,3
    • Pry up on the corner of the hinge cover with an iFixit opening tool.
    • Use the iFixit opening tool along both sides and the front of the hinge cover to release it.
    • Lean the display back as far as it goes and lift up on the hinge cover to remove.
  3. Dell Inspiron 1721 DVD Drive Replacement, Keyboard: 步骤 3 中的图像 1,3 Dell Inspiron 1721 DVD Drive Replacement, Keyboard: 步骤 3 中的图像 2,3 Dell Inspiron 1721 DVD Drive Replacement, Keyboard: 步骤 3 中的图像 3,3
    • Remove four 3mm Phillips #1 screws from the top of the keyboard.
    • Use an iFixit opening tool to slide the keyboard upwards toward the display.
    • Slide the keyboard until it is clear of the lock tab, and lift it up to remove.
  4. Dell Inspiron 1721 DVD Drive Replacement, Back Cover: 步骤 4 中的图像 1,1
    • Disconnect the touch pad connector.
  5. Dell Inspiron 1721 DVD Drive Replacement: 步骤 5 中的图像 1,3 Dell Inspiron 1721 DVD Drive Replacement: 步骤 5 中的图像 2,3 Dell Inspiron 1721 DVD Drive Replacement: 步骤 5 中的图像 3,3
    • Lay the device flat and remove the 17 7mm Phillips #0 screws.
    • Use an iFixit opening tool to separate the back cover.
    • Remove the back cover.
  6. Dell Inspiron 1721 DVD Drive Replacement, DVD Drive: 步骤 6 中的图像 1,2 Dell Inspiron 1721 DVD Drive Replacement, DVD Drive: 步骤 6 中的图像 2,2
    • Grab the DVD drive and pull straight out from the side of the case to remove.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 163
