简介
If your Dell Inspiron 1721 has a loud fan or is prone to overheating, use this guide to replace the internal fan.
Internal fans circulate cool air to a heat-sink, allowing the CPU to stay at a low temperature, even during stressful performance. Dusty internal fans will restrict airflow in any device.
Before using this guide, verify that the computer is completely shutdown.
你所需要的
Slide tabs outward to undo the locks.
Grab and pull the battery away from the device to remove.
Pry up on the corner of the hinge cover with an iFixit opening tool.
Use the iFixit opening tool along both sides and the front of the hinge cover to release it.
Lean the display back as far as it goes and lift up on the hinge cover to remove.
Remove four 3mm Phillips #1 screws from the top of the keyboard.
Use an iFixit opening tool to slide the keyboard upwards toward the display.
Slide the keyboard until it is clear of the lock tab, and lift it up to remove.
Unscrew the Phillips #0 screws attaching the heat sink to the motherboard.
Carefully remove the heat sink from the motherboard.
另外一个人完成了本指南。
