简介
A smooth touch pad with soft clicks, and is compatible with gestures.
你所需要的
Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
Lift the latch holding down the ribbon cable connected to the touch pad.
Remove the three screws holding down the bracket on the bottom portion of the touch pad using a Phillips #0 screwdriver.
Remove the four screws holding down the bracket on the upper portion of the touch pad using a Phillips #0 screwdriver.
Remove the bracket on the bottom portion of the touchpad by carefully peeling it away, as it is held by adhesives, then set it aside.
