跳转到主内容
Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement
你所需要的
  1. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Base Cover: 步骤 1 中的图像 1,2 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Base Cover: 步骤 1 中的图像 2,2
    • Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 步骤 2 中的图像 2,2
    • Loosen the three captive screws that secure the base closer to the hinges.
    • Do not attempt to remove the three captive screws! You need only to loosen them. They're supposed to stay on the base cover.
  3. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 步骤 3 中的图像 3,3
    • Carefully pry the base cover using an iFixit opening tool in the crevice near the hinges. Guide the pick along the edges and slightly lift upwards as you go along.
    • Do not start from the speaker end of the edges when opening, or you may cause further damage to your device!
  4. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 步骤 4 中的图像 3,3
    • Carefully remove the base cover from the laptop.
  5. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Fan: 步骤 5 中的图像 1,2 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Fan: 步骤 5 中的图像 2,2
    • Gently remove the I/O cable.
  6. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 步骤 6 中的图像 1,2 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 步骤 6 中的图像 2,2
    • Remove the fan cable from the motherboard.
  7. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 步骤 7 中的图像 1,1
    • Remove two 3 mm screws that secure the fan using a Phillips #0 screwdriver.
  8. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 步骤 8 中的图像 1,2 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 步骤 8 中的图像 2,2
    • There is a little piece of tape/sticker on the fan that connects it to the heat sink. Gently remove this.
    • Lift the fan off the palm rest assembly.
  9. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Heatsink: 步骤 9 中的图像 1,2 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Heatsink: 步骤 9 中的图像 2,2
    • Loosen seven 3 mm captive screws securing the heatsink to the motherboard using a Phillips #0 screwdriver.
  10. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 步骤 10 中的图像 1,3 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 步骤 10 中的图像 2,3 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: 步骤 10 中的图像 3,3
    • Lift the heatsink off the motherboard.
结论
Delia Padilla
于08/23/22注册
564 声望
创作了5篇指南
团队
Gateway, Team 1-3, Class Fall 2022 Gateway, Team 1-3, Class Fall 2022 的会员
GCC-CLASS-F22S1G3
4 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 92
