跳转到主内容
Dell Inspiron 17-7746 Battery Replacement
你所需要的
  1. Dell Inspiron 17-7746 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Disconnect the laptop from the AC adapter and turn off the laptop.
  2. Dell Inspiron 17-7746 Battery Replacement: 步骤 2 中的图像 1,1
    • Place the laptop so the bottom faces up.
  3. Dell Inspiron 17-7746 Battery Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 17-7746 Battery Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 17-7746 Battery Replacement: 步骤 3 中的图像 3,3
    • Remove the silver 15mm PH 1 screw that holds the plastic cover in place over the battery.
    • Remove the 8mm PH 1 screw that holds the plastic cover in place over the battery.
    • Keep the screws together because the length of the screws will matter when you reassemble.
  4. Dell Inspiron 17-7746 Battery Replacement: 步骤 4 中的图像 1,1
    • Using the metal jimmy, pry up the first half of the cover.
  5. Dell Inspiron 17-7746 Battery Replacement: 步骤 5 中的图像 1,1
    • Apply pressure with your fingertips on top of the cover and drag toward the front of the laptop. This will make the plate slide off exposing the hard drive.
  6. Dell Inspiron 17-7746 Battery Replacement: 步骤 6 中的图像 1,2 Dell Inspiron 17-7746 Battery Replacement: 步骤 6 中的图像 2,2
    • Remove the two black PH1 6mm screws that anchor the battery.
  7. Dell Inspiron 17-7746 Battery Replacement: 步骤 7 中的图像 1,1
    • Grab the black tab on the battery with index finger and thumb.
    • If the Tab is broken or missing, use the plastic spudger to pry the battery out far enough to grab the battery by hand.
    • Avoid applying too much pressure on the battery with the plastic spudger. It might puncture the battery.
  8. Dell Inspiron 17-7746 Battery Replacement: 步骤 8 中的图像 1,1
    • Pull upwards, removing the battery from the laptop.
    • Ensure replacement battery has no bulging or has no cracks and lies flat in its location.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 15
总计 1,585
