跳转到主内容
Dell Inspiron 17-7737 Battery Replacement
你所需要的
  1. Dell Inspiron 17-7737 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Close the display and turn the computer over.
    • Remove the 5 mm screw on the left-hand side of the battery cover using a Phillips #1 screwdriver.
    • Loosen the captive screw on the right-hand side using a Phillips #1 screwdriver.
  2. Dell Inspiron 17-7737 Battery Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 17-7737 Battery Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 17-7737 Battery Replacement: 步骤 2 中的图像 3,3
    • Pry out the battery cover from the computer base using an opening tool.
  3. Dell Inspiron 17-7737 Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the three screws that secure the battery to the base using a Phillips #1 screwdriver.
  4. Dell Inspiron 17-7737 Battery Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 17-7737 Battery Replacement: 步骤 4 中的图像 2,2
    • Using the adhesive pull tab, pull and lift the battery out of the computer's base.
    • If using any tools to get ahold of the adhesive tab, try not to puncture your battery, as battery acids are extremely toxic to humans.
结论
Mark Batista
于03/16/23注册
457 声望
创作了3篇指南
团队
UMass Dartmouth, Team 7-7, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-7, Ryckebusch Spring 2023 的会员
UMASSD-RYCKEBUSCH-S23S7G7
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 34
总计 267
