跳转到主内容
Dell Inspiron 17-5755 Keyboard Replacement
你所需要的
  1. Dell Inspiron 17-5755 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the computer has been shut down, and isn't plugged into an outlet before attempting to remove the battery.
  2. Dell Inspiron 17-5755 Keyboard Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 17-5755 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Find the battery release latch on the bottom side of the computer.
    • Slide the latch to the left until you hear a "click". This indicates that the battery has been released.
  3. Dell Inspiron 17-5755 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Safely remove the battery from the laptop.
  4. Dell Inspiron 17-5755 Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,2 Dell Inspiron 17-5755 Keyboard Replacement, Keyboard: 步骤 4 中的图像 2,2
    • Open the display of the laptop as far as possible, and locate the tabs which secure the keyboard to the laptop.
  5. Dell Inspiron 17-5755 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Use a plastic opening tool to gently release the tabs that secure the keyboard to the laptop.
  6. Dell Inspiron 17-5755 Keyboard Replacement: 步骤 6 中的图像 1,2 Dell Inspiron 17-5755 Keyboard Replacement: 步骤 6 中的图像 2,2
    • Carefully lift the keyboard from the laptop, being mindful of any attachments that it may have.
  7. Dell Inspiron 17-5755 Keyboard Replacement: 步骤 7 中的图像 1,3 Dell Inspiron 17-5755 Keyboard Replacement: 步骤 7 中的图像 2,3 Dell Inspiron 17-5755 Keyboard Replacement: 步骤 7 中的图像 3,3
    • Lift the zero insertion force (ZIF) tab that secures the keyboard back light ribbon cable
    • Afterwards, carefully detach the backlight cable from the laptop.
  8. Dell Inspiron 17-5755 Keyboard Replacement: 步骤 8 中的图像 1,3 Dell Inspiron 17-5755 Keyboard Replacement: 步骤 8 中的图像 2,3 Dell Inspiron 17-5755 Keyboard Replacement: 步骤 8 中的图像 3,3
    • Gently release the ZIF tab that secures the keyboard ribbon cable to the laptop.
    • Afterwards, carefully slide the cable out of its slot.
  9. Dell Inspiron 17-5755 Keyboard Replacement: 步骤 9 中的图像 1,2 Dell Inspiron 17-5755 Keyboard Replacement: 步骤 9 中的图像 2,2
    • Now that the keyboard is detached from the laptop, you may safely remove it.
结论
2等其他人完成本指南。
团队
USF Tampa, Team S6-G1, Lacy Spring 2017 USF Tampa, Team S6-G1, Lacy Spring 2017 的会员
USFT-LACY-S17S6G1
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 11
总计 716
