跳转到主内容
Dell Inspiron 17-5755 Hard Drive Replacement
你所需要的
  1. Dell Inspiron 17-5755 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the computer has been shut down, and isn't plugged into an outlet before attempting to remove the battery.
  2. Dell Inspiron 17-5755 Hard Drive Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 17-5755 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Find the battery release latch on the bottom side of the computer.
    • Slide the latch to the left until you hear a "click". This indicates that the battery has been released.
  3. Dell Inspiron 17-5755 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Safely remove the battery from the laptop.
  4. Dell Inspiron 17-5755 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,3 Dell Inspiron 17-5755 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 2,3 Dell Inspiron 17-5755 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 3,3
    • Turn over your laptop and locate the two screws which secure the base cover.
    • Use a Phillips #0 screwdriver to unscrew the 8mm screws which secure the base cover.
  5. Dell Inspiron 17-5755 Hard Drive Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 17-5755 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Locate the tabs that hold the base cover to the laptop and use a plastic opening tool to gently release the base cover.
  6. Dell Inspiron 17-5755 Hard Drive Replacement: 步骤 6 中的图像 1,3 Dell Inspiron 17-5755 Hard Drive Replacement: 步骤 6 中的图像 2,3 Dell Inspiron 17-5755 Hard Drive Replacement: 步骤 6 中的图像 3,3
    • Now with the base cover removed, you may lift it off of the laptop and continue.
  7. Dell Inspiron 17-5755 Hard Drive Replacement: 步骤 7 中的图像 1,3 Dell Inspiron 17-5755 Hard Drive Replacement: 步骤 7 中的图像 2,3 Dell Inspiron 17-5755 Hard Drive Replacement: 步骤 7 中的图像 3,3
    • Locate the hard drive cable, and disconnect it from the laptop by lifting the latch which secures the cable.
  8. Dell Inspiron 17-5755 Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the four 8mm screws which secure the hard drive assembly to the laptop.
  9. Dell Inspiron 17-5755 Hard Drive Replacement: 步骤 9 中的图像 1,3 Dell Inspiron 17-5755 Hard Drive Replacement: 步骤 9 中的图像 2,3 Dell Inspiron 17-5755 Hard Drive Replacement: 步骤 9 中的图像 3,3
    • Carefully remove the hard drive and its assembly from the laptop.
  10. Dell Inspiron 17-5755 Hard Drive Replacement: 步骤 10 中的图像 1,3 Dell Inspiron 17-5755 Hard Drive Replacement: 步骤 10 中的图像 2,3 Dell Inspiron 17-5755 Hard Drive Replacement: 步骤 10 中的图像 3,3
    • Remove the interposer by grabbing the black portion of the assembly, and pulling it away from the hard drive.
    • Be sure to not remove the interposer by pulling on the cable attached to it.
  11. Dell Inspiron 17-5755 Hard Drive Replacement: 步骤 11 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the four 4mm screws on either side of the hard drive assembly.
    • These screws are very small. Make sure not to misplace them.
  12. Dell Inspiron 17-5755 Hard Drive Replacement: 步骤 12 中的图像 1,3 Dell Inspiron 17-5755 Hard Drive Replacement: 步骤 12 中的图像 2,3 Dell Inspiron 17-5755 Hard Drive Replacement: 步骤 12 中的图像 3,3
    • Safely remove the hard drive assembly from the hard drive to complete the process.
结论
2等其他人完成本指南。
Jeff
于02/15/17注册
385 声望
创作了3篇指南
团队
USF Tampa, Team S6-G1, Lacy Spring 2017 USF Tampa, Team S6-G1, Lacy Spring 2017 的会员
USFT-LACY-S17S6G1
3 名成员
创作了5篇指南
2条评论
My question is, the hard drive is this a 7mm, 12mm or 15mm drive bay? I want to put a 4tb in my laptop but those are 15mm size and I can’t find what the size limit of the bay is.
Rachael Strange - 回复
I want to put a 4tb harddrive in my laptop.
Those only come in 15mm.
will this drive bay hold 15mm sized drives?
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 2,560
