跳转到主内容
Dell Inspiron 17-5749 Keyboard Replacement
你所需要的
  1. Dell Inspiron 17-5749 Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 17-5749 Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.16
    • Turn off power to the laptop.
    • Unplug the charging cable from the laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
  2. Dell Inspiron 17-5749 Keyboard Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 17-5749 Keyboard Replacement: 步骤 2 中的图像 2,2
    • First carefully turn the laptop over so you can access the battery.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
  3. Dell Inspiron 17-5749 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,3 Dell Inspiron 17-5749 Keyboard Replacement, Keyboard: 步骤 3 中的图像 2,3 Dell Inspiron 17-5749 Keyboard Replacement, Keyboard: 步骤 3 中的图像 3,3
    • Turn the computer over and open the display as far as possible
    • Using a plastic opening tool, release the tabs that secure the keyboard to the palm-rest assembly.
    • Before turning over the keyboard, be careful not to pull the keyboard too far away as it could damage the connected ribbon cables.
  4. Dell Inspiron 17-5749 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Carefully turn the keyboard over and place it on the palm rest assembly.
    • Lift the latches and disconnect the keyboard cable and keyboard back-light cable from the system board.
    • Lift the keyboard along with the cables, off the palm-rest assembly and set it aside.
结论
Christopher Tran
于02/13/18注册
1,162 声望
创作了12篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 586
