跳转到主内容
Dell Inspiron 17-5749 Hard Drive Replacement
你所需要的
  1. Dell Inspiron 17-5749 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 17-5749 Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.16
    • Turn off power to the laptop.
    • Unplug the charging cable from the laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
  2. Dell Inspiron 17-5749 Hard Drive Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 17-5749 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • First carefully turn the laptop over so you can access the battery.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
  3. Dell Inspiron 17-5749 Hard Drive Replacement, Back Cover: 步骤 3 中的图像 1,3 Dell Inspiron 17-5749 Hard Drive Replacement, Back Cover: 步骤 3 中的图像 2,3 Dell Inspiron 17-5749 Hard Drive Replacement, Back Cover: 步骤 3 中的图像 3,3
    • Remove the two 5.5mm screws that secure the base cover to the computer's base.
    • Using the plastic opening tool, carefully pry open the base cover starting from the center.
    • Lift the base cover upwards to remove and set it aside.
  4. Dell Inspiron 17-5749 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,3 Dell Inspiron 17-5749 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 2,3 Dell Inspiron 17-5749 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 3,3
    • Remove the 2.5mm screw that secures the hard-drive assembly to the computer base.
    • Using the pull tab, slide the hard-drive assembly to disconnect it from the system board.
    • Lift the hard-drive assembly off the computer base
结论
另外一个人完成了本指南。
Christopher Tran
于02/13/18注册
1,162 声望
创作了12篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 12
总计 822
