当前版本的文档还未经巡查,您可以查看最新的已查核版本。
在这个步骤中使用的工具:
Anti-Static Wrist Strap
$7.95
购买
Turn off power to the laptop.
Unplug the charging cable from the laptop.
Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
First carefully turn the laptop over so you can access the battery.
Switch each of the battery latches to the "unlocked" position.
Pull battery upwards by the tab to remove from the laptop.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
