跳转到主内容
Dell Inspiron 17-5748 Speakers Replacement
你所需要的
  1. Dell Inspiron 17-5748 Speakers Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop upside down.
    • Locate the battery lock latches.
  2. Dell Inspiron 17-5748 Speakers Replacement: 步骤 2 中的图像 1,1
    • Slide both lock latches to the unlocked position.
  3. Dell Inspiron 17-5748 Speakers Replacement: 步骤 3 中的图像 1,1
    • Lift the battery up and out of the laptop battery socket.
  4. Dell Inspiron 17-5748 Speakers Replacement, Speakers: 步骤 4 中的图像 1,3 Dell Inspiron 17-5748 Speakers Replacement, Speakers: 步骤 4 中的图像 2,3 Dell Inspiron 17-5748 Speakers Replacement, Speakers: 步骤 4 中的图像 3,3
    • Remove the 4.5 mm Phillips #0 screw holding the Optical Drive in place.
    • Slide the Optical Drive out of the device.
  5. Dell Inspiron 17-5748 Speakers Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 17-5748 Speakers Replacement: 步骤 5 中的图像 2,2
    • Remove the two 4.5 mm Phillips #0 screws on the access panel door.
  6. Dell Inspiron 17-5748 Speakers Replacement: 步骤 6 中的图像 1,2 Dell Inspiron 17-5748 Speakers Replacement: 步骤 6 中的图像 2,2
    • Using a plastic opening tool, pry open the access panel, exposing the disk drive, RAM, and wireless module.
  7. Dell Inspiron 17-5748 Speakers Replacement: 步骤 7 中的图像 1,3 Dell Inspiron 17-5748 Speakers Replacement: 步骤 7 中的图像 2,3 Dell Inspiron 17-5748 Speakers Replacement: 步骤 7 中的图像 3,3
    • Remove the 2.5 mm Phillips #0 screw securing the hard drive.
    • Slide the hard drive out using the pull tab.
    • Remove the hard drive from the device.
  8. Dell Inspiron 17-5748 Speakers Replacement: 步骤 8 中的图像 1,1
    • Open the laptop and locate the keyboard.
  9. Dell Inspiron 17-5748 Speakers Replacement: 步骤 9 中的图像 1,2 Dell Inspiron 17-5748 Speakers Replacement: 步骤 9 中的图像 2,2
    • Locate the 5 keyboard tabs at the side of the keyboard closest to the screen.
    • Using a metal spudger, gently pry the keyboard tabs inwards until they loosened. You should hear a click.
  10. Dell Inspiron 17-5748 Speakers Replacement: 步骤 10 中的图像 1,2 Dell Inspiron 17-5748 Speakers Replacement: 步骤 10 中的图像 2,2
    • Do not remove the keyboard completely. The ribbon cable underneath, attaching it to the motherboard, must still be detached.
    • Lift the keyboard partially and flip it over.
  11. Dell Inspiron 17-5748 Speakers Replacement: 步骤 11 中的图像 1,2 Dell Inspiron 17-5748 Speakers Replacement: 步骤 11 中的图像 2,2
    • Detach the ribbon cable from the motherboard by tilting up the black clip, releasing the cable.
    • Gently detach the cable and the keyboard from the laptop.
  12. Dell Inspiron 17-5748 Speakers Replacement: 步骤 12 中的图像 1,1
    • Remove the five 4.5 mm Phillips #0 screws found under the keyboard.
  13. Dell Inspiron 17-5748 Speakers Replacement: 步骤 13 中的图像 1,3 Dell Inspiron 17-5748 Speakers Replacement: 步骤 13 中的图像 2,3 Dell Inspiron 17-5748 Speakers Replacement: 步骤 13 中的图像 3,3
    • Do not fully remove the palm rest until the ribbon cable underneath is detached.
    • Using a plastic opening tool, separate the plastic palm rest and partially lift the palm rest from the device.
    • Remove both ends of the ribbon cable. This can be done by flipping up the black tabs securing both ends.
    • Remove the palm rest from the device.
  14. Dell Inspiron 17-5748 Speakers Replacement: 步骤 14 中的图像 1,3 Dell Inspiron 17-5748 Speakers Replacement: 步骤 14 中的图像 2,3 Dell Inspiron 17-5748 Speakers Replacement: 步骤 14 中的图像 3,3
    • Locate the first speaker.
    • Unplug the speaker cable.
  15. Dell Inspiron 17-5748 Speakers Replacement: 步骤 15 中的图像 1,2 Dell Inspiron 17-5748 Speakers Replacement: 步骤 15 中的图像 2,2
    • Lift the speaker from the corner.
    • Remove the speaker.
  16. Dell Inspiron 17-5748 Speakers Replacement: 步骤 16 中的图像 1,2 Dell Inspiron 17-5748 Speakers Replacement: 步骤 16 中的图像 2,2
    • Using the plastic opening tool, gently remove the second speaker.
结论
另外一个人完成了本指南。
Bradley
于02/12/18注册
235 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 558
