跳转到主内容
Dell Inspiron 17-5748 Keyboard Replacement
你所需要的
  1. Dell Inspiron 17-5748 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop upside down.
    • Locate the battery lock latches.
  2. Dell Inspiron 17-5748 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Slide both lock latches to the unlocked position.
  3. Dell Inspiron 17-5748 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Lift the battery up and out of the laptop battery socket.
  4. Dell Inspiron 17-5748 Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,1
    • Open the laptop and locate the keyboard.
  5. Dell Inspiron 17-5748 Keyboard Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 17-5748 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Locate the 5 keyboard tabs at the side of the keyboard closest to the screen.
    • Using a metal spudger, gently pry the keyboard tabs inwards until they loosened. You should hear a click.
  6. Dell Inspiron 17-5748 Keyboard Replacement: 步骤 6 中的图像 1,2 Dell Inspiron 17-5748 Keyboard Replacement: 步骤 6 中的图像 2,2
    • Do not remove the keyboard completely. The ribbon cable underneath, attaching it to the motherboard, must still be detached.
    • Lift the keyboard partially and flip it over.
  7. Dell Inspiron 17-5748 Keyboard Replacement: 步骤 7 中的图像 1,2 Dell Inspiron 17-5748 Keyboard Replacement: 步骤 7 中的图像 2,2
    • Detach the ribbon cable from the motherboard by tilting up the black clip, releasing the cable.
    • Gently detach the cable and the keyboard from the laptop.
结论
Justine Vaca
于02/12/18注册
121 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 11
总计 641
