跳转到主内容
Dell Inspiron 17-3721 Keyboard Replacement
你所需要的
  1. Dell Inspiron 17-3721 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,2 Dell Inspiron 17-3721 Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Use a plastic opening tool or a metal spudger to pry out the tabs on top of the keyboard.
    • After prying the tabs up, carefully pull the keyboard out of the laptop.
    • Use caution when prying the tabs up or lifting the keyboard up, as the plastic material and the strip on the keyboard can easily break.
  2. Dell Inspiron 17-3721 Keyboard Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 17-3721 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Once the keyboard is lifted, locate the release tab.
    • Using a plastic opening tool or your finger, lift the tab so that it opens .
    • Once the tab is open, the strip on the keyboard can be removed.
结论
另外一个人完成了本指南。
Kevin Prairie
于03/20/18注册
445 声望
创作了4篇指南
团队
UMass Dartmouth, Team S5-G3, Peak Spring 2018 UMass Dartmouth, Team S5-G3, Peak Spring 2018 的会员
UMASSD-PEAK-S18S5G3
3 名成员
创作了7篇指南
一条评论
Wow that was easy! Thanks :D
Isaac Pettis - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 23
总计 472
