跳转到主内容
Dell Inspiron 17-3721 Hard Drive Replacement
你所需要的
  1. Dell Inspiron 17-3721 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,3 Dell Inspiron 17-3721 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,3 Dell Inspiron 17-3721 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 3,3
    • Remove the two 6.5 mm PH1 Philips head screws on the back panel.
    • Lift up the small panel from the top, using the plastic opening tools if necessary.
  2. Dell Inspiron 17-3721 Hard Drive Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 17-3721 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Remove the two 5.5 mm PH1 Phillips head screws holding in the hard drive.
    • Slide the hard drive out of its slot and lift it out of the device.
    • At the time of the creation of this guide, our device did not include a hard drive.
结论
Kevin Prairie
于03/20/18注册
445 声望
创作了4篇指南
团队
UMass Dartmouth, Team S5-G3, Peak Spring 2018 UMass Dartmouth, Team S5-G3, Peak Spring 2018 的会员
UMASSD-PEAK-S18S5G3
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 954
