跳转到主内容
Dell Inspiron 17-3721 CMOS Battery Replacement
你所需要的
  1. Dell Inspiron 17-3721 CMOS Battery Replacement, CMOS Battery: 步骤 1 中的图像 1,3 Dell Inspiron 17-3721 CMOS Battery Replacement, CMOS Battery: 步骤 1 中的图像 2,3 Dell Inspiron 17-3721 CMOS Battery Replacement, CMOS Battery: 步骤 1 中的图像 3,3
    • Remove the two 6.5 mm PH1 Philips head screws on the back panel.
    • Lift up the small panel from the top, using the plastic opening tools if necessary.
  2. Dell Inspiron 17-3721 CMOS Battery Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 17-3721 CMOS Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the CMOS battery with the plastic opening tools.
    • Be careful while prying it open, the battery holder can break if you use too much force.
    • Do not use metal tools when touching anything that can have an electric charge.
结论
团队
UMass Dartmouth, Team S5-G3, Peak Spring 2018 UMass Dartmouth, Team S5-G3, Peak Spring 2018 的会员
UMASSD-PEAK-S18S5G3
3 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 41
总计 1,056
