跳转到主内容
配件
没有特定配件。
  1. Remove the single Philips screw securing the disc drive.
    • Remove the single Philips screw securing the disc drive.
    • Pull the disc drive out.
  2. Remove the 22 M2.5x5 Philips screws securing the palmrest to the base. Remove the seven remaining M2x2.5 screws securing the palmrest to the base. Unscrew the two captive screws securing the RAM/HDD door to the base.
    • Remove the 22 M2.5x5 Philips screws securing the palmrest to the base.
    • Remove the seven remaining M2x2.5 screws securing the palmrest to the base.
    • Unscrew the two captive screws securing the RAM/HDD door to the base.
    • This must be done in order to access hidden screws under the hard drive.
    • Under the RAM/HDD door, unscrew the hard drive caddy. Remove the caddy.
    • Remove the three M2.5x5 screws from under where the hard drive was.
  3. Pop the four keyboard clips with a plastic spudger. As you do the first one, pry to get under the keyboard with your hand.
    • Pop the four keyboard clips with a plastic spudger. As you do the first one, pry to get under the keyboard with your hand.
    • Remove the keyboard cable from the motherboard connector.
    In the process of removing the keyboard I broke one of the keyboard clips. Any suggested quick fixes? I'm thinking of just using tape to hold the left side down but would prefer a less permanent solution.
    Roberto Godinez - 回复
  4. Remove the palmrest cables from the motherboard connectors. Remove the seven M2.5x5 screws securing the palmrest to the base.
    • Remove the palmrest cables from the motherboard connectors.
    • Remove the seven M2.5x5 screws securing the palmrest to the base.
    • Lift the palmrest.
    Only the bottom two smaller connectors need to be disconnected. The larger one can remain.
    anonymous 5159 - 回复
  5. Use a plastic spudger to get under the CR2032 cell and pry it out carefully.
    • Use a plastic spudger to get under the CR2032 cell and pry it out carefully.
    This was very helpful!
    anonymous 5159 - 回复
结论
12等其他人完成本指南。
Joseph Sctbunio
于2017年09月23日注册
6,419 信誉积分
创作了42篇指南
7条评论
thanks for your help!!!
E P - 回复
I’m happy that my guide helped you!
Joseph Sctbunio -
Lot of screws, wouldn’t even tried this without these instruction.
Thank you.
d223e
Don Endress - 回复
Thanks for the instructions. Computer starts up great now.
jkleinjans - 回复
doresc sa comand pentru Dell Inspiron 17 N7010 BIOS Baterie. 1 bucata. cum se procedeaza?
Florentin Manolea - 回复
Many thanks for an excellent, clear guide! Successfully followed it earlier.
Dave Rourke - 回复
Thanks, it worked great!
Cristian Puscas - 回复
添加评论
浏览统计数据:
过去的24小时: 6
过去的7天: 19
过去的30天: 126
总计 14,826
