跳转到主内容
Dell Inspiron 16-7610 Battery Replacement
你所需要的
  1. Dell Inspiron 16-7610 Battery Replacement, Back Case: 步骤 1 中的图像 1,2 Dell Inspiron 16-7610 Battery Replacement, Back Case: 步骤 1 中的图像 2,2
    • Flip the device over, so the backside is facing up.
    • Use a Phillips #00 screwdriver to remove four 4.00 mm screws.
    • Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
    • The last two screws should remain in the back case and can't be removed.
    • Three of the screws are dummy screws, only screwed into retainers. They are not holding anything in and can be left in place for simplicity.
  2. Dell Inspiron 16-7610 Battery Replacement: 步骤 2 中的图像 1,1
    • -Use the opening tool between the seams of the top and bottom case to pry the back case off of the laptop.
    • Undo the clips gently as you pry the back of the device to avoid breaking them when removing the back case.
    • Remove the back case from the device.
  3. Dell Inspiron 16-7610 Battery Replacement, Battery: 步骤 3 中的图像 1,3 Dell Inspiron 16-7610 Battery Replacement, Battery: 步骤 3 中的图像 2,3 Dell Inspiron 16-7610 Battery Replacement, Battery: 步骤 3 中的图像 3,3
    • Use a Phillips #00 to remove the five screws securing the battery to the laptop.
    • Pull the bundled cable away from the connector in the same direction as the wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Use both hands to life the battery up and remove it from the laptop.
结论
Michael Torres
于02/02/23注册
145 声望
创作了2篇指南
团队
Gateway, Team 1-3, Pee Spring 2023 Gateway, Team 1-3, Pee Spring 2023 的会员
GCC-PEE-S23S1G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 21
过去 30 天: 52
总计 1,617
