跳转到主内容
Dell Inspiron 16 7610 Back Case Replacement
你所需要的
  1. Dell Inspiron 16 7610 Back Case Replacement, Back Case: 步骤 1 中的图像 1,2 Dell Inspiron 16 7610 Back Case Replacement, Back Case: 步骤 1 中的图像 2,2
    • Flip the device over, so the backside is facing up.
    • Use a Phillips #00 screwdriver to remove four 4.00 mm screws.
    • Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
    • The last two screws should remain in the back case and can't be removed.
    • Three of the screws are dummy screws, only screwed into retainers. They are not holding anything in and can be left in place for simplicity.
  2. Dell Inspiron 16 7610 Back Case Replacement: 步骤 2 中的图像 1,1
    • -Use the opening tool between the seams of the top and bottom case to pry the back case off of the laptop.
    • Undo the clips gently as you pry the back of the device to avoid breaking them when removing the back case.
    • Remove the back case from the device.
结论
Jerson Gomez
于02/02/23注册
877 声望
创作了3篇指南
团队
Gateway, Team 1-3, Pee Spring 2023 Gateway, Team 1-3, Pee Spring 2023 的会员
GCC-PEE-S23S1G3
4 名成员
创作了6篇指南
一条评论
Followed instructions. No clips broken but still cannot close the back cover. There’s a small gab in between the mouse and the cover when I close it.
Enos Nii Armah - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 63
总计 817
