跳转到主内容
Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement
你所需要的
  1. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement, AC/DC Power Jack Plug Socket: 步骤 1 中的图像 1,3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement, AC/DC Power Jack Plug Socket: 步骤 1 中的图像 2,3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement, AC/DC Power Jack Plug Socket: 步骤 1 中的图像 3,3
    • Flip the laptop over with the bottom facing up.
    • Pull the latches away from each other to release the battery.
    • Remove the battery.
  2. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 步骤 2 中的图像 2,2
    • Throughout this guide, be sure to keep all screws in a safe place so they do not get lost. You should also keep them organized so they do not get mixed up.
    • Remove the 4 screws in the battery compartment using a 2.0mm magnetic phillips head screwdriver.
  3. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 步骤 3 中的图像 2,2
    • The screws do not come out of the access door. Do not try to remove them.
    • Loosen the 3 screws on the access door using the 2.0mm phillips head screwdriver.
    • Remove the access door.
  4. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 步骤 4 中的图像 3,3
    • Remove the disk drive screw using the 2.0mm phillips head screwdriver.
    • Remove the disk drive from the laptop.
    • Remove the 2 screws under the disk drive with the 2.0mm phillips head screwdriver.
  5. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 步骤 5 中的图像 2,2
    • Remove the 4 hard drive screws using the 2.0mm phillips head screwdriver.
    • Pull the tab to remove the hard drive from the computer.
  6. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 步骤 6 中的图像 1,1
    • Remove the 5 bottom base screws using the 2.0mm phillips head screwdriver.
  7. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 步骤 7 中的图像 1,3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 步骤 7 中的图像 2,3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 步骤 7 中的图像 3,3
    • Depress the keyboard latches to release the keyboard with the 2.0mm flat head screwdriver.
    • Lift the keyboard up carefully.
    • Release the two ribbon cables underneath the keyboard.
  8. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 步骤 8 中的图像 1,2 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 步骤 8 中的图像 2,2
    • Remove the 6 palm rest screws using the 2.0mm phillips head screwdriver.
    • Unplug the 3 ribbon cables.
  9. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 步骤 9 中的图像 1,3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 步骤 9 中的图像 2,3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 步骤 9 中的图像 3,3
    • Take your time on this step and be careful to not break the plastic palm rest.
    • Separate the palm rest from the bottom base using the 2.0mm flat head screwdriver as a lever.
    • Unplug the ribbon cable underneath the palm rest.
  10. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 步骤 10 中的图像 1,3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 步骤 10 中的图像 2,3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: 步骤 10 中的图像 3,3
    • Remove the 2 DC jack bracket screws with the 2.0mm phillips head screwdriver and remove the bracket.
    • Unplug and remove the old DC jack.
结论
Follow these instructions in reverse order to reassemble your device.
Allen Van Den Boom
于09/29/17注册
109 声望
撰写一个指南
团队
Michigan Tech, Team S3-G1, Galliah Fall 2017 Michigan Tech, Team S3-G1, Galliah Fall 2017 的会员
MTU-GALLIAH-F17S3G1
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 1,443
