跳转到主内容
Dell Inspiron 15R SE 7520 Display Assembly Replacement
你所需要的
  1. Dell Inspiron 15R SE 7520 Display Assembly Replacement, Disconnecting the Antenna Cables: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • Disconnect the antenna cables from the connectors on the Mini-Card.
  2. Dell Inspiron 15R SE 7520 Display Assembly Replacement, Peel the Tape: 步骤 2 中的图像 1,1
    • Peel the tape that secures the display cable to the system board and then disconnect the display cable from the connector on the system board.
  3. Dell Inspiron 15R SE 7520 Display Assembly Replacement, Display Cable Routing: 步骤 3 中的图像 1,1
    • Make a note of the display cable routing and remove the cable from the routing guides.
  4. Dell Inspiron 15R SE 7520 Display Assembly Replacement, Remove the Screws: 步骤 4 中的图像 1,1
    • Remove the screws that secure the display assembly to the computer base.
  5. Dell Inspiron 15R SE 7520 Display Assembly Replacement, Lifting the Display Assembly: 步骤 5 中的图像 1,1
    • Lift the display assembly off the computer base.
  6. Dell Inspiron 15R SE 7520 Display Assembly Replacement, Placing the Display Assembly: 步骤 6 中的图像 1,1
    • Place the NEW display assembly in position and replace the screws that secure the display assembly to the computer base.
  7. Dell Inspiron 15R SE 7520 Display Assembly Replacement, Route the Display Cable: 步骤 7 中的图像 1,1
    • Route the display cable through the routing guides and connect the display cable to the connector on the system board.
  8. Dell Inspiron 15R SE 7520 Display Assembly Replacement, Adhering the Tape: 步骤 8 中的图像 1,1
    • Adhere the tape that secures the display cable to the system board.
  9. Dell Inspiron 15R SE 7520 Display Assembly Replacement, Connecting the Antenna Cables: 步骤 9 中的图像 1,1
    • Connect the antenna cables to the connectors on the Mini-Card.
终点
另外一个人完成了本指南。
Terrence15
于12/18/17注册
79,522 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 10
总计 801
