当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Turn the device over and locate the battery.
Place thumbs on each latch and push outwards.
Push and slide the battery away from you.
Locate the RAM compartment and the screw on the right hand side. Remove the cover.
Locate and remove the 2.5 mm x 5 mm screw on the upper right hand side of the compartment.
Turn the device around and open it up.
Using your index finger, push down on the F1 and F7 keys.
Using your index finger, push down on the x icon and Home keys.
Locate the keyboard lining (between the black and silver).
Place your spudger between the keyboard lining behind the F1 and F7 keys and pull up.
Place your spudger between the keyboard lining behind the x icon and Home keys and pull up.
Carefully pull and turn the keyboard over.
Lift the black lever.
Remove the keyboard cable
取消:我没有完成这个指南。
另外一个人完成了本指南。
与3其他贡献者
于02/14/15注册
843 声望
创作了6篇指南
徽章: 12
+ 9更多徽章
SDSU-SHEPPARD-W15S2G2
2 名成员
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 6
总计 1,324
