跳转到主内容
Dell Inspiron 15R 5537 Palm Rest Replacement
你所需要的
  1. Dell Inspiron 15R 5537 Palm Rest Replacement, Battery: 步骤 1 中的图像 1,1
    • Before working inside your computer, read the safety information that shipped with your computer.
    • Close the display and turn over the computer to see the battery locking tabs.
  2. Dell Inspiron 15R 5537 Palm Rest Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 15R 5537 Palm Rest Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 15R 5537 Palm Rest Replacement: 步骤 2 中的图像 3,3
    • Pull both of the locking tabs outwards until they both click to release the battery.
    • Pull the battery out by lifting it from the top and sliding it forward.
  3. Dell Inspiron 15R 5537 Palm Rest Replacement, Keyboard: 步骤 3 中的图像 1,3 Dell Inspiron 15R 5537 Palm Rest Replacement, Keyboard: 步骤 3 中的图像 2,3 Dell Inspiron 15R 5537 Palm Rest Replacement, Keyboard: 步骤 3 中的图像 3,3
    • Turn the laptop over so that the keyboard is facing up.
    • Use an opening tool to pry the keyboard from the base of the laptop.
    • Once the top of the keyboard is released, slide the keyboard upwards.
    • Be sure not to pull the keyboard straight up; this could damage the keyboard ribbon cable.
  4. Dell Inspiron 15R 5537 Palm Rest Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 15R 5537 Palm Rest Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 15R 5537 Palm Rest Replacement: 步骤 4 中的图像 3,3
    • Use an opening tool to remove the keyboard ribbon from the latch by lifting the tab on top.
    • Once lifted, disconnect the ribbon and replace with a new keyboard.
  5. Dell Inspiron 15R 5537 Palm Rest Replacement, Wi-Fi Module: 步骤 5 中的图像 1,1
    • Once the keyboard is removed, the Wi-Fi module will be accessible.
  6. Dell Inspiron 15R 5537 Palm Rest Replacement: 步骤 6 中的图像 1,2 Dell Inspiron 15R 5537 Palm Rest Replacement: 步骤 6 中的图像 2,2
    • Use the opening tool to lift both antenna cables upward from the Wi-Fi module.
  7. Dell Inspiron 15R 5537 Palm Rest Replacement: 步骤 7 中的图像 1,3 Dell Inspiron 15R 5537 Palm Rest Replacement: 步骤 7 中的图像 2,3 Dell Inspiron 15R 5537 Palm Rest Replacement: 步骤 7 中的图像 3,3
    • Remove the 3mm Phillips #000 screw securing the Wi-Fi module.
    • Lift the Wi-Fi module up and out of the laptop.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin". After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is in Sleep or On state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
  8. Dell Inspiron 15R 5537 Palm Rest Replacement, Remove the Screws: 步骤 9 中的图像 1,1
    • Remove the screws that secure the hard-drive assembly to the computer base.
  9. Dell Inspiron 15R 5537 Palm Rest Replacement, Sliding the Hard Drive Assembly: 步骤 10 中的图像 1,1
    • Slide the hard-drive assembly forward to disconnect the hard-drive assembly from the system board.
  10. Dell Inspiron 15R 5537 Palm Rest Replacement, Lifting the Hard Drive Assembly: 步骤 11 中的图像 1,1
    • Using the pull-tab, lift the hard-drive assembly out of the computer base.
  11. Dell Inspiron 15R 5537 Palm Rest Replacement, Remove the Screws: 步骤 12 中的图像 1,1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  12. Dell Inspiron 15R 5537 Palm Rest Replacement, Lifting the Hard-Drive Bracket: 步骤 13 中的图像 1,1
    • Lift the hard-drive bracket off the hard drive.
  13. Dell Inspiron 15R 5537 Palm Rest Replacement, Align the Screw Holes: 步骤 14 中的图像 1,1
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  14. Dell Inspiron 15R 5537 Palm Rest Replacement, Replace the Screws: 步骤 15 中的图像 1,1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  15. Dell Inspiron 15R 5537 Palm Rest Replacement, Placing the Hard Drive Assembly: 步骤 16 中的图像 1,1
    • Slide and place the hard-drive assembly in the hard-drive bay.
  16. Dell Inspiron 15R 5537 Palm Rest Replacement, Sliding the Hard-Drive Assembly: 步骤 17 中的图像 1,1
    • Slide the hard-drive assembly backward to connect the hard-drive assembly to the system board.
  17. Dell Inspiron 15R 5537 Palm Rest Replacement, Replace the Screws: 步骤 18 中的图像 1,1
    • Replace the screws that secure the hard-drive assembly to the computer base.
  18. Dell Inspiron 15R 5537 Palm Rest Replacement, Palm Rest: 步骤 19 中的图像 1,1
    • Remove thirteen 5mm Phillips #000 screws from the back cover of the laptop.
  19. Dell Inspiron 15R 5537 Palm Rest Replacement: 步骤 20 中的图像 1,3 Dell Inspiron 15R 5537 Palm Rest Replacement: 步骤 20 中的图像 2,3 Dell Inspiron 15R 5537 Palm Rest Replacement: 步骤 20 中的图像 3,3
    • Use the opening tool to unplug the palm rest cables and slide the cables out.
  20. Dell Inspiron 15R 5537 Palm Rest Replacement: 步骤 21 中的图像 1,1
    • Remove seven 5mm Phillips #000 screws from the midframe.
  21. Dell Inspiron 15R 5537 Palm Rest Replacement: 步骤 22 中的图像 1,3 Dell Inspiron 15R 5537 Palm Rest Replacement: 步骤 22 中的图像 2,3 Dell Inspiron 15R 5537 Palm Rest Replacement: 步骤 22 中的图像 3,3
    • Use the opening tool to lift the edges of the palm rest. Once all of the sides are lifted, pull the palm rest off.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 472
