跳转到主内容
Dell Inspiron 15R 5521 Memory Module Replacement
你所需要的
  1. Dell Inspiron 15R 5521 Memory Module Replacement, Loosen the Screws: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • Loosen the captive screw that secures the memory-module cover to the computer base.
  2. Dell Inspiron 15R 5521 Memory Module Replacement, Lifting the Memory Module: 步骤 2 中的图像 1,1
    • Using your fingertips, lift the memory-module cover out of the slots on the computer base.
  3. Dell Inspiron 15R 5521 Memory Module Replacement, Popping up the Memory Module: 步骤 3 中的图像 1,1
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
  4. Dell Inspiron 15R 5521 Memory Module Replacement, Remove the Memory Module: 步骤 4 中的图像 1,1
    • Remove the memory module from the memory-module connector.
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  5. Dell Inspiron 15R 5521 Memory Module Replacement, Sliding the Memory Module: 步骤 6 中的图像 1,1
    • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
  6. Dell Inspiron 15R 5521 Memory Module Replacement, Slide the Tabs: 步骤 7 中的图像 1,1
    • Slide the tabs on the memory-module cover into the slots on the computer base and snap the memory-module cover into place.
  7. Dell Inspiron 15R 5521 Memory Module Replacement, Tighten the Screw: 步骤 8 中的图像 1,1
    • Tighten the captive screw that secures the memory-module cover to the computer base.
终点
Terrence15
于12/18/17注册
79,522 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 246
