简介
Replacing or upgrading your laptop’s hard drive is a great way to get some extra life out of your device.
你所需要的
Locate and loosen the three 3 mm screws.
Remove the plastic casing with the screws attached.
3等其他人完成本指南。
2条评论
I have a Dell 15R 5537. The drive removal is about the same. There are only two screws holding the drive, though. They’re located at the back of the drive. Push the drive back to clear the connector and pull up aided by a clear plastic pull tab on the drive.
It worked and was well worth installing an SSD.
