跳转到主内容
Dell Inspiron 1564 RAM Replacement
你所需要的
  1. Dell Inspiron 1564 RAM Replacement, RAM: 步骤 1 中的图像 1,2 Dell Inspiron 1564 RAM Replacement, RAM: 步骤 1 中的图像 2,2
    • Locate the battery latch on the bottom of the computer and slide it to the right.
    • While holding the battery latch, pull the battery away from the device.
  2. Dell Inspiron 1564 RAM Replacement: 步骤 2 中的图像 1,1
    • With the Phillips #0 screwdriver, loosen the three screws from the cover behind the battery latch.
  3. Dell Inspiron 1564 RAM Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 1564 RAM Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 1564 RAM Replacement: 步骤 3 中的图像 3,3
    • Locate the RAM on the bottom of the computer.
    • Remove the RAM by gently pulling back the small clips along the side of the RAM, and lifting the RAM upwards so the RAM is now angled.
    • Pull the RAM away from the device.
    • Repeat the actions above for the second stick of RAM.
    • When reinstalling the RAM, put it back in at an angle in the socket, and make sure the RAM is audiblely clicked into place.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 982
