跳转到主内容
Dell Inspiron 1564 Hard Drive Replacement
你所需要的
  1. Dell Inspiron 1564 Hard Drive Replacement, Remove Battery: 步骤 1 中的图像 1,2 Dell Inspiron 1564 Hard Drive Replacement, Remove Battery: 步骤 1 中的图像 2,2
    • Locate battery latch on bottom of computer and slide to right.
    • While holding battery latch, pull the battery away from device and the battery will come free.
  2. Dell Inspiron 1564 Hard Drive Replacement, Remove Bottom Cover Screws: 步骤 2 中的图像 1,1
    • With a J0 screwdriver bit, loosen all screws from the backing above the battery latch and remove the covering.
  3. Dell Inspiron 1564 Hard Drive Replacement, Hard Drive Removal: 步骤 3 中的图像 1,2 Dell Inspiron 1564 Hard Drive Replacement, Hard Drive Removal: 步骤 3 中的图像 2,2
    • Locate the three 4mm screws securing the hard drive and unscrew them with a J0 screwdriver.
    • Slide the hard drive to the left to unplug the SATA data and SATA power cables, then gently pry upwards and pull the drive away from device.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 1,914
