跳转到主内容
加入维修社区 - 创建账户
Dell Inspiron 1545 RAM Replacement
你所需要的
  1. Dell Inspiron 1545 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 RAM Replacement: 步骤 2 中的图像 1,1
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 RAM Replacement: 步骤 3 中的图像 1,1
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 RAM Replacement, Base Cover: 步骤 4 中的图像 1,1
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
  5. Dell Inspiron 1545 RAM Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 1545 RAM Replacement: 步骤 5 中的图像 2,2
    • Carefully lift the base cover vertically away from the laptop.
  6. Dell Inspiron 1545 RAM Replacement, RAM: 步骤 6 中的图像 1,1
    • Spread apart the securing clips on each end of the memory stick until the memory stick pops up.
    • Remove the memory stick from the laptop.
    • Repeat these steps to remove the second memory stick.
结论
11等其他人完成本指南。
Nathan Lemay
于04/16/14注册
3,160 声望
创作了15篇指南
团队
Cal Poly, Team 9-14, Regan Spring 2014 Cal Poly, Team 9-14, Regan Spring 2014 的会员
CPSU-REGAN-S14S9G14
4 名成员
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 19
过去 30 天: 31
总计 3,385
