跳转到主内容
Dell Inspiron 1545 Power Button Board Replacement
你所需要的
  1. Dell Inspiron 1545 Power Button Board Replacement, Power Button Board: 步骤 1 中的图像 1,1
    • Turn the laptop off and disconnect it from all power sources.
    • Turn the laptop over so that the bottom is facing upwards.
  2. Dell Inspiron 1545 Power Button Board Replacement: 步骤 2 中的图像 1,1
    • Slide the release latch while simultaneously pulling the battery outwards.
  3. Dell Inspiron 1545 Power Button Board Replacement: 步骤 3 中的图像 1,1
    • Slide the battery completely out of the bay.
  4. Dell Inspiron 1545 Power Button Board Replacement: 步骤 4 中的图像 1,1
    • Once the battery has been removed, take out the two screws (3mm Phillips #1) beneath it. These screws hold the center control cover in place.
  5. Dell Inspiron 1545 Power Button Board Replacement: 步骤 5 中的图像 1,1
    • Flip the laptop back over to the front and push the screen open as far as possible.
  6. Dell Inspiron 1545 Power Button Board Replacement: 步骤 6 中的图像 1,3 Dell Inspiron 1545 Power Button Board Replacement: 步骤 6 中的图像 2,3 Dell Inspiron 1545 Power Button Board Replacement: 步骤 6 中的图像 3,3
    • The center control cover is very fragile; be careful when prying it off.
    • Pry the center control cover off of the laptop using a plastic opening tool. On the right side of the cover, there is a small divot to help you start removing the cover.
    • Carefully lift the central control cover away from the laptop.
  7. Dell Inspiron 1545 Power Button Board Replacement: 步骤 7 中的图像 1,1
    • Remove the two screws (5mm Phillips #1) at the top of the keyboard.
  8. Dell Inspiron 1545 Power Button Board Replacement: 步骤 8 中的图像 1,1
    • Be careful when pulling the keyboard away from the laptop, you may damage the connector holding it to the motherboard.
    • Using your hands, push the keyboard out and away from the laptop.
  9. Dell Inspiron 1545 Power Button Board Replacement: 步骤 9 中的图像 1,2 Dell Inspiron 1545 Power Button Board Replacement: 步骤 9 中的图像 2,2
    • Lift the connector latch to remove the keyboard cable from the motherboard.
    • Lift the keyboard away from the laptop.
  10. Dell Inspiron 1545 Power Button Board Replacement: 步骤 10 中的图像 1,1
    • Lift the connector latch to remove the power button board from the motherboard.
    • Pull on the blue plastic tab to help prevent causing any damage to the connector.
  11. Dell Inspiron 1545 Power Button Board Replacement: 步骤 11 中的图像 1,1
    • Pry the power button board out with your finger.
    • Pull the power button board away from the laptop.
结论
Michael Hill
于02/28/18注册
193 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 2,429
