当前版本的文档还未经巡查,您可以查看最新的已查核版本。
The Center Control Cover is VERY fragile, be careful when using prying tools.
Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here.
Carefully lift the Center Control Cover away from the laptop.
Slide the keyboard out and away from the laptop and lift it up to access the keyboard connector.
Do not pull hard on the keyboard while removing it, you may damage the keyboard or the keyboard connector.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
