跳转到主内容
简介
There are multiple issues that can arise with the keyboard, this guide will allow you to fix a number of them. Using this guide you can clean the keyboard or access some of the more complex components of the laptop.
  1. Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Slide the release latch while simultaneously pulling backwards on the battery.
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Slide the battery out of the battery bay.
    • Slide the battery out of the battery bay.
  4. Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The screws are connected to the base cover by a washer anddo not remove from the base cover.
  5. Carefully lift the base cover vertically away from the laptop. Carefully lift the base cover vertically away from the laptop.
    • Carefully lift the base cover vertically away from the laptop.
  6. After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
    • After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
  7. Flip the laptop over to the front and open the display as far as possible.
    • Flip the laptop over to the front and open the display as far as possible.
  8. The Center Control Cover is VERY fragile,  be careful when using prying tools. Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here. Carefully lift the Center Control Cover away from the laptop.
    • The Center Control Cover is VERY fragile, be careful when using prying tools.
    • Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here.
    • Carefully lift the Center Control Cover away from the laptop.
  9. Remove the two screws (5mm Phillips #1) at the top of the keyboard.
    • Remove the two screws (5mm Phillips #1) at the top of the keyboard.
  10. Slide the keyboard out and away from the laptop and lift it up to access the keyboard connector.
    • Slide the keyboard out and away from the laptop and lift it up to access the keyboard connector.
    • Do not pull hard on the keyboard while removing it, you may damage the keyboard or the keyboard connector.
  11. Lift the connector latch that secures the keyboard cable to the connector on the motherboard and remove the cable.
    • Lift the connector latch that secures the keyboard cable to the connector on the motherboard and remove the cable.
    The connector latch is the black piece.
    Maurice Volaski - 回复
    Good tip! As shown. flips up and toward user
    Tom Borden - 回复
  12. Lift the keyboard up and away from the laptop.
    • Lift the keyboard up and away from the laptop.
结论
12等其他人完成本指南。
Nathan Lemay
于2014年04月16日注册
2,881 信誉积分
创作了15篇指南
团队
Cal Poly, Team 9-14, Regan Spring 2014 Cal Poly, Team 9-14, Regan Spring 2014 的会员
CPSU-REGAN-S14S9G14
4 名成员
创作了15篇指南
2条评论
Step 4 and 5 are not needed.
James Thrun - 回复
Steps 4 and 5 are unnecessary for removing the keyboard. Other than that, well done.
lee - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 7
过去的30天: 25
总计 5,716
