跳转到主内容
Dell Inspiron 1545 Hard Drive Replacement
你所需要的
  1. Dell Inspiron 1545 Hard Drive Replacement, Remove the Screws: 步骤 1 中的图像 1,1
    • CAUTION: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • Remove the two screws securing the hard drive assembly to the computer base.
  2. Dell Inspiron 1545 Hard Drive Replacement, Sliding the Hard Drive Assembly: 步骤 2 中的图像 1,1
    • Slide the hard drive assembly out of the bay.
  3. Dell Inspiron 1545 Hard Drive Replacement, Remove the Screws: 步骤 3 中的图像 1,1
    • Remove the two screws (one from either side) securing the hard drive cage and bezel to the hard drive.
  4. Dell Inspiron 1545 Hard Drive Replacement, Remove the Hard Drive Bezel: 步骤 4 中的图像 1,1
    • Remove the hard drive bezel.
  5. Dell Inspiron 1545 Hard Drive Replacement, Lifting the Hard Drive: 步骤 5 中的图像 1,2 Dell Inspiron 1545 Hard Drive Replacement, Lifting the Hard Drive: 步骤 5 中的图像 2,2
    • Lift the hard drive cage off the hard drive.
  6. Dell Inspiron 1545 Hard Drive Replacement, Replace the Hard Drive Cage: 步骤 6 中的图像 1,2 Dell Inspiron 1545 Hard Drive Replacement, Replace the Hard Drive Cage: 步骤 6 中的图像 2,2
    • Replace the hard drive cage and the hard drive bezel.
  7. Dell Inspiron 1545 Hard Drive Replacement, Replace the Screws: 步骤 7 中的图像 1,1
    • Replace the two screws (one on either side) that secure the hard drive cage and bezel to the NEW hard drive.
  8. Dell Inspiron 1545 Hard Drive Replacement, Sliding the Hard Drive Assembly: 步骤 8 中的图像 1,1
    • Slide the hard drive assembly into the bay.
  9. Dell Inspiron 1545 Hard Drive Replacement, Replace the Screws: 步骤 9 中的图像 1,1
    • Replace the two screws that secure the hard drive assembly to the computer base.
    • NOTICE: Before turning on the computer, replace all screws and ensure that no stray screws remain inside the computer. Failure to do so may result in damage to the computer.
终点
5等其他人完成本指南。
Terrence15
于12/18/17注册
79,831 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,991篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 50
总计 6,382
