当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
Turn the laptop over to its back.
Slide the release latch while simultaneously pulling backwards on the battery.
Slide the battery out of the battery bay.
After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
Flip the laptop over to the front and open the display as far as possible.
The Center Control Cover is VERY fragile, be careful when using prying tools.
Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here.
Carefully lift the Center Control Cover away from the laptop.
取消:我没有完成这个指南。
2等其他人完成本指南。
与3其他贡献者
于04/16/14注册
3,052 声望
创作了15篇指南
徽章: 12
+ 9更多徽章
CPSU-REGAN-S14S9G14
4 名成员
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 13
总计 2,678
