跳转到主内容
Dell Inspiron 1545 Center Control Cover Replacement
你所需要的
  1. Dell Inspiron 1545 Center Control Cover Replacement, Battery: 步骤 1 中的图像 1,1
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 Center Control Cover Replacement: 步骤 2 中的图像 1,1
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 Center Control Cover Replacement: 步骤 3 中的图像 1,1
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 Center Control Cover Replacement, Center Control Cover: 步骤 4 中的图像 1,1
    • After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
  5. Dell Inspiron 1545 Center Control Cover Replacement: 步骤 5 中的图像 1,1
    • Flip the laptop over to the front and open the display as far as possible.
  6. Dell Inspiron 1545 Center Control Cover Replacement: 步骤 6 中的图像 1,3 Dell Inspiron 1545 Center Control Cover Replacement: 步骤 6 中的图像 2,3 Dell Inspiron 1545 Center Control Cover Replacement: 步骤 6 中的图像 3,3
    • The Center Control Cover is VERY fragile, be careful when using prying tools.
    • Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here.
    • Carefully lift the Center Control Cover away from the laptop.
结论
2等其他人完成本指南。
Nathan Lemay
于04/16/14注册
3,064 声望
创作了15篇指南
团队
Cal Poly, Team 9-14, Regan Spring 2014 Cal Poly, Team 9-14, Regan Spring 2014 的会员
CPSU-REGAN-S14S9G14
4 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 22
总计 2,730
