跳转到主内容
Dell Inspiron 1545 CPU Heat Sink Replacement
你所需要的
  1. Dell Inspiron 1545 CPU Heat Sink Replacement, Battery: 步骤 1 中的图像 1,1
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 CPU Heat Sink Replacement: 步骤 2 中的图像 1,1
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 CPU Heat Sink Replacement: 步骤 3 中的图像 1,1
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 CPU Heat Sink Replacement, Base Cover: 步骤 4 中的图像 1,1
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
  5. Dell Inspiron 1545 CPU Heat Sink Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 1545 CPU Heat Sink Replacement: 步骤 5 中的图像 2,2
    • Carefully lift the base cover vertically away from the laptop.
  6. Dell Inspiron 1545 CPU Heat Sink Replacement, CPU Heat Sink: 步骤 6 中的图像 1,1
    • Loosen the 5 screws (4mm, Phillips #1) that secure the CPU Heat Sink to the motherboard.
    • These screws are held in place by a washer so you should not be able to completely remove the screws.
  7. Dell Inspiron 1545 CPU Heat Sink Replacement: 步骤 7 中的图像 1,1
    • Pull up on the Heat Sink unit to remove it.
结论
6等其他人完成本指南。
Nathan Lemay
于04/16/14注册
3,145 声望
创作了15篇指南
团队
Cal Poly, Team 9-14, Regan Spring 2014 Cal Poly, Team 9-14, Regan Spring 2014 的会员
CPSU-REGAN-S14S9G14
4 名成员
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 2,298
