跳转到主内容
Dell Inspiron 1526 Webcam Replacement
你所需要的
  1. Dell Inspiron 1526 Webcam Replacement, Battery: 步骤 1 中的图像 1,3 Dell Inspiron 1526 Webcam Replacement, Battery: 步骤 1 中的图像 2,3 Dell Inspiron 1526 Webcam Replacement, Battery: 步骤 1 中的图像 3,3
    • Slide the unlock button to the left to release the battery.
    • Slide the battery away from the laptop to remove.
    • The unlock button is located on the bottom of the laptop.
  2. Dell Inspiron 1526 Webcam Replacement, Keyboard: 步骤 2 中的图像 1,1
    • Loosen the two 3.5mm Phillips #1 screws in the battery bay.
  3. Dell Inspiron 1526 Webcam Replacement: 步骤 3 中的图像 1,1
    • Flip the laptop over.
    • Lift the control cover by prying the right side of the cover with an iFixit opening tool.
  4. Dell Inspiron 1526 Webcam Replacement: 步骤 4 中的图像 1,1
    • Carefully lift the control cover up and forward to reveal a single ribbon cable.
  5. Dell Inspiron 1526 Webcam Replacement: 步骤 5 中的图像 1,1
    • Use tweezers to squeeze the tabs on the connector and remove the ribbon cable.
  6. Dell Inspiron 1526 Webcam Replacement: 步骤 6 中的图像 1,2 Dell Inspiron 1526 Webcam Replacement: 步骤 6 中的图像 2,2
    • Remove the control cover.
  7. Dell Inspiron 1526 Webcam Replacement: 步骤 7 中的图像 1,1
    • Remove the two 3mm Phillips #1 screws at the top of the keyboard where the control cover was.
  8. Dell Inspiron 1526 Webcam Replacement: 步骤 8 中的图像 1,1
    • Lift the keyboard gently from the top, but do not remove completely.
    • Looking under the keyboard, towards the touch-pad in the center, lift up the black tab on the connector with tweezers for the keyboard ribbon cable.
  9. Dell Inspiron 1526 Webcam Replacement: 步骤 9 中的图像 1,2 Dell Inspiron 1526 Webcam Replacement: 步骤 9 中的图像 2,2
    • Remove the keyboard.
  10. Dell Inspiron 1526 Webcam Replacement, Screen: 步骤 10 中的图像 1,2 Dell Inspiron 1526 Webcam Replacement, Screen: 步骤 10 中的图像 2,2
    • Remove the six plastic pads around the bezel using an iFixit opening pick.
    • Remove the six 3mm Phillips #0 screws under each pad.
  11. Dell Inspiron 1526 Webcam Replacement: 步骤 11 中的图像 1,3 Dell Inspiron 1526 Webcam Replacement: 步骤 11 中的图像 2,3 Dell Inspiron 1526 Webcam Replacement: 步骤 11 中的图像 3,3
    • Open the computer so that it rests flat on the table.
    • Separate the bezel from the black plastic frame using a spudger.
    • There are a dozen snaps around the perimeter of the bezel and there are two between the pivot joints of the laptop.
  12. Dell Inspiron 1526 Webcam Replacement: 步骤 12 中的图像 1,2 Dell Inspiron 1526 Webcam Replacement: 步骤 12 中的图像 2,2
    • Remove the two 3mm Phillips #1 screws at the bottom of the display panel.
    • Lift the display slightly from the top, then pull outwards.
    • Flip the display panel around to the back.
    • Disconnect the connector and remove the ribbon cable.
  13. Dell Inspiron 1526 Webcam Replacement, Webcam: 步骤 13 中的图像 1,2 Dell Inspiron 1526 Webcam Replacement, Webcam: 步骤 13 中的图像 2,2
    • Detach the webcam connector.
  14. Dell Inspiron 1526 Webcam Replacement: 步骤 14 中的图像 1,1
    • From both sides, pry and pull upwards from the back of the display cover.
    • This module has no screws affixing it to the display cover; it is held in by snapping it into the plastic brackets.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 79
