跳转到主内容
Dell Inspiron 1526 Keyboard Replacement
你所需要的
  1. Dell Inspiron 1526 Keyboard Replacement, Battery: 步骤 1 中的图像 1,3 Dell Inspiron 1526 Keyboard Replacement, Battery: 步骤 1 中的图像 2,3 Dell Inspiron 1526 Keyboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Slide the unlock button to the left to release the battery.
    • Slide the battery away from the laptop to remove.
    • The unlock button is located on the bottom of the laptop.
  2. Dell Inspiron 1526 Keyboard Replacement, Keyboard: 步骤 2 中的图像 1,1
    • Loosen the two 3.5mm Phillips #1 screws in the battery bay.
  3. Dell Inspiron 1526 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Flip the laptop over.
    • Lift the control cover by prying the right side of the cover with an iFixit opening tool.
  4. Dell Inspiron 1526 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Carefully lift the control cover up and forward to reveal a single ribbon cable.
  5. Dell Inspiron 1526 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Use tweezers to squeeze the tabs on the connector and remove the ribbon cable.
  6. Dell Inspiron 1526 Keyboard Replacement: 步骤 6 中的图像 1,2 Dell Inspiron 1526 Keyboard Replacement: 步骤 6 中的图像 2,2
    • Remove the control cover.
  7. Dell Inspiron 1526 Keyboard Replacement: 步骤 7 中的图像 1,1
    • Remove the two 3mm Phillips #1 screws at the top of the keyboard where the control cover was.
  8. Dell Inspiron 1526 Keyboard Replacement: 步骤 8 中的图像 1,1
    • Lift the keyboard gently from the top, but do not remove completely.
    • Looking under the keyboard, towards the touch-pad in the center, lift up the black tab on the connector with tweezers for the keyboard ribbon cable.
  9. Dell Inspiron 1526 Keyboard Replacement: 步骤 9 中的图像 1,2 Dell Inspiron 1526 Keyboard Replacement: 步骤 9 中的图像 2,2
    • Remove the keyboard.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 123
