跳转到主内容
Dell Inspiron 1526 Heat Sink Replacement
你所需要的
  1. Dell Inspiron 1526 Heat Sink Replacement, Battery: 步骤 1 中的图像 1,3 Dell Inspiron 1526 Heat Sink Replacement, Battery: 步骤 1 中的图像 2,3 Dell Inspiron 1526 Heat Sink Replacement, Battery: 步骤 1 中的图像 3,3
    • Slide the unlock button to the left to release the battery.
    • Slide the battery away from the laptop to remove.
    • The unlock button is located on the bottom of the laptop.
  2. Dell Inspiron 1526 Heat Sink Replacement, Heat Sink: 步骤 2 中的图像 1,2 Dell Inspiron 1526 Heat Sink Replacement, Heat Sink: 步骤 2 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the eight 3mm screws from the rear casing of the laptop.
  3. Dell Inspiron 1526 Heat Sink Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 1526 Heat Sink Replacement: 步骤 3 中的图像 2,2
    • Loosen the five captive Phillips #0 screws from the heat sink.
    • Lift the heat sink from the motherboard.
  4. Dell Inspiron 1526 Heat Sink Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 1526 Heat Sink Replacement: 步骤 4 中的图像 2,2
    • Apply a pea-sized amount of new thermal paste to the CPU and GPU.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 152
